Vapor lock or not?
Old Jul 14, 2003 | 11:46 AM
EricWTT's Avatar
EricWTT
Cruising
Default Vapor lock or not?
Ok some say that fuel injection cannot have vapor lock, but this is my situation.
I live in las vegas the current temp is 115F, I drive my car for about 20 minutes and the engine temp ends up at about 200 – 220F.
Then the throttle starts to sputter and when I turn it off the car has a hard time starting.
The fuel rails are very hot.
Things I have replaced too try to salve the problem:
New fuel pump
Accel 30 lb./hr. injectors
MAT Sensor Relocating Kit
New MAT Sensor
New Throttle Position Sensor
Two new O2 Sensors
New radiator fluid Temp Sensor
Throttle Performance Switch
New Opti Spark Distributor Cap Kit
Hypertech 160 Degree Thermostat
Throttle Body By-Pass (I just used a new hose)
Rebuilt ECM
Manual fan switch
The only thing I can think of know is the fuel regulator.
Any suggestions would be very appreciated.
Sincerely EricWTT
http://ericwtturner.tripod.com/vette.htm
Old Jul 14, 2003 | 11:55 AM
atotalnincompoop's Avatar
atotalnincompoop
Default Re: Vapor lock or not? (EricWTT)
does the car overheat? :confused:
Old Jul 14, 2003 | 01:00 PM
EricWTT's Avatar
EricWTT
Cruising
no, just problems with the throttle.
Old Jul 14, 2003 | 01:13 PM
EricWTT's Avatar
EricWTT
Cruising
Default Re: Vapor lock or not? (atotalnincompoop)
cool car :)
I am originally from Saint John NB, Canada I moved here three and a half years ago.
Old Jul 14, 2003 | 01:15 PM
JCAIRE2's Avatar
JCAIRE2
Why do you have 30lb injectors? I looked at your page and didn't see anything about increasing the displacement of you engine, so why the bigger injectors?
Can't help with the problems once your up to temp, but the warm/hot hard starting might be due to the bigger injectors. Good luck, hope you find better help :cheers:
Old Jul 14, 2003 | 01:31 PM
EricWTT's Avatar
EricWTT
Cruising
Default Re: Vapor lock or not? (JCAIRE2)
no problem. :)
I know it isn't the injectors though cause I was having the problem before I change them.
Old Jul 14, 2003 | 01:48 PM
John Row's Avatar
John Row
It is possible that the Cat. Conv. are plugged?
Look around for vacuum leaks.
Just a guess here, but try removing the throttle performance switch. That along with the bigger injectors maybe flooding or causing a rich condition.
Old Jul 15, 2003 | 12:50 AM
EricWTT's Avatar
EricWTT
Cruising
Default Re: Vapor lock or not? (John Row)
I'll try the first two tomorrow but the throttle performance switch didn't do anything and I had the problem before I got the bigger injectors.
If I leave the AC off it runs between 185-195
which is good except it about 115F right know :mad
So I dieing from the heat.
Old Jul 15, 2003 | 01:15 AM
Southern Comfort's Avatar
Southern Comfort
Anything is possible in Vegas....Anything :crazy:
To Vapor lock or not?
