Interior Ventilation
Old Jul 14, 2003 | 12:25 PM
TomHamill's Avatar
TomHamill
St. Jude Donor '05
Default Interior Ventilation
Ever since I got my 1995 LT1 about a year ago the air flow from the dash vents has been weak. Now there is only flow from the defroster vents and floor vents at the same time no matter what selection I make. The flow varies with fan speed and is pretty strong at maximum. Any ideas ? :banghead:
Old Jul 14, 2003 | 01:47 PM
9T4YY1's Avatar
9T4YY1
Default Re: Interior Ventilation (TomHamill)
I've heard that carbon builds up on the switch contacts. If you take it apart and take it off it should help. Mine craps out occasionally due to build up. Is your fan working ??
Old Jul 14, 2003 | 02:10 PM
TomHamill's Avatar
TomHamill
St. Jude Donor '05
Default Re: Interior Ventilation (9T4YY1)
Yea... fan works fine low to high, high to low. I'm not familiar with the different types ( if any ) of systems vettes have. Mine has the push button selection with the green light. Do you mean clean the contacts behind this panel ? :confused: :confused:
To Interior Ventilation
