DFI Program
Old Jul 14, 2003 | 03:23 PM
xxxtremevette's Avatar
xxxtremevette
6th Gear
Default DFI Program
Does anyone have a base program that will work for a 406ci engine
Big Cam, Strip Dominator Intake with a lingenfelter elbow. 42.5lb/hr injectors
If so email me at xxxtremevette@rogers.com
Old Jul 14, 2003 | 04:40 PM
jburnett's Avatar
jburnett
Default Re: DFI Program (xxxtremevette)
6.32 or 7.0? If it's 6.32 I may have something that will work. If it's DFI Gen7 you can VERY easily build your own in the Global Parameters; you can do the same in the old 6.32 but it's usually NOWHERE near accurate and tends to be SO fat that you could wash out the rings if it's a new mill. Or, you can go to Global in 6.32 and be VERY CONSERVATIVE on you power figures when it asks and it will be a little closer.
-Jeb
Old Jul 14, 2003 | 05:19 PM
xxxtremevette
6th Gear
Default Re: DFI Program (jburnett)
I'm using 6.32. I will try going through the global being extremely conservative. If you might have something that works I would be very interested. Thanks
Old Jul 16, 2003 | 10:00 PM
JUAN J SANCHEZ's Avatar
JUAN J SANCHEZ
I have a strip dominator intake I just converted for my 383 in my 89.Sounds like we have a very similiar intake and fuel management combo. I have 30lbs injectors , 6.32 DFI , 1000cfm throttle body. I 've never used a converted single plane set up but I've used super rams and minirams and theoretically the single plane falls right in between both and I think will actually make more power (hp-tor)and is less cam sensitive. Anyway I have a program for a 406 with a super ram box intake with 36lbs inj that made 440hp/500lbs of torque but I 'm not sure I'd know how to get it to you. Let me know how your combo works out I'm very curious. :chevy
To DFI Program
