A/C Not Cold
Old Jul 14, 2003 | 08:36 PM
Yellow95's Avatar
Yellow95
Default A/C Not Cold
Looks like my '95 six speed baby is going to the doctor. (A/C specialist)
Took it to my local mechanic who purged and filled the A/C system, this worked a little but it still can't keep up with the California heat. Also had a leak check done, no leaks.
There are no codes, the air gets a little cold, and the compressor seems to labor too much. The cycling of the A/C is very noticable.
Any thoughts about what might be going on?
:confused:
Old Jul 14, 2003 | 10:14 PM
sumoboy's Avatar
sumoboy
Default Re: A/C Not Cold (Yellow95)
usually when it cycles often it sounds like it's low on freon. Also check to see if the low freon switch is going bad.
Old Jul 14, 2003 | 10:30 PM
white90conv's Avatar
white90conv
Compressor cycling could be low refrigerant. However, you just had it charged. A plugged orifice tube could also produce cycling.
Old Jul 15, 2003 | 11:06 PM
wirenut3's Avatar
wirenut3
I changed mine to 134A it is nice :lol: :cool:
Old Jul 16, 2003 | 12:47 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: A/C Not Cold (sumoboy)
Check the high-pressure switch,too. Also, don't forget to change the dryer/accumulator, too, as it's the filter of your A/C sytem. :lol:
Old Jul 18, 2003 | 12:13 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Hope its just low on charge.....if you have to replace the A/C Pump...lots of $$$$$$$$$$$$$$$$$$
Anyway
Good Luck
tony
:smash:
To A/C Not Cold
