Low coolant light
Old Jul 15, 2003 | 10:20 AM
DocToss's Avatar
DocToss
Default Low coolant light
I pulled and cleaned my radiator and it took a couple of days and a few burps to finally get my low coolant light to go off. However, I notice that it does not light when I turn the engine on. I believe some of the DIC lights are not supposed to come on with the engine. Is this normal for the low coolant light, or do I need to change the bulb? Thanks
Old Jul 15, 2003 | 11:19 AM
blackvette89's Avatar
blackvette89
Default Re: Low coolant light (DocToss)
on my 89 the only lights i get during startup is the alarm and another one i'm not sure but i'm positive its not the coolant light. i hope this helps! :cool:
Old Jul 15, 2003 | 12:57 PM
DocToss's Avatar
DocToss
Default Re: Low coolant light (blackvette89)
Thanks,that does help. Are you talking about the lights in the DIC? That is where my low coolant light is.
Old Jul 15, 2003 | 01:13 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
The Low Coolant warning light is not active in bulb test. You're OK.
To Low coolant light
