ground wire location 89
Old Jul 15, 2003 | 11:15 AM
blackvette89's Avatar
blackvette89
Default ground wire location 89
i read a few wiring diagrams and can't locate the ground wire for the cluster. i beleive its the D1 ground. my cluster goes dim with the highbeam and turn signals bright and always on. i'm referiing to the wiring diagram at the web site i found here "the 84". thanks for the help!
Old Jul 15, 2003 | 01:41 PM
black_89_vette's Avatar
black_89_vette
Default Re: ground wire location 89 (blackvette89)
dunno the answer to your question but it looks like I posted it cause of the closeness of our names. Your post caught my eye. Wish I could help.
Old Jul 16, 2003 | 04:08 AM
LD85's Avatar
LD85
Default Re: ground wire location 89 (black_89_vette)
ttt
Old Jul 16, 2003 | 08:23 AM
Hooked on Vettes's Avatar
Hooked on Vettes
Take a piece of wire and attach it to the battery negative terminal and the other end to pin D1. If that cures your problem the ground wire is open some where. You can also use an ohm meter to check continuity from D1 to ground.
Or you can splice/attach a wire between D1 and D3 ( Black/White) on the same connector. It's also a ground wire for the dash cluster.
Old Jul 16, 2003 | 11:05 AM
blackvette89
Default Re: ground wire location 89 (Hooked on Vettes)
thanks, i'll let u know howit works out! :cheers:
To ground wire location 89
