Re: Replacement 2 bar sensor for #16009886? (gene284)
Gene the wiring harness is made to keep people from installing the wrong map sensor so to put a 2 bar on it is necessary to cut a slot so it will fit.
Is that why you think you have the wrong part.
I called GM not to far back and was interested in the price of a 2 bar MAP. I took the part number off of a post I searched for in the archive and gave it to the parts guy. He said the part number had been changed to 16254539.
Re: Replacement 2 bar sensor for #16009886? (black bart)
The stock ECM can't use the 2 bar map data for anything, so if that's the case, don't you have to upgrade to an aftermarket EFI system to get it work anyway? And if so, do you have to specify a specific wiring harness for the MAP sensor you're using anyway?
Re: Replacement 2 bar sensor for #16009886? (vvv90)
Matt if you look at his post about three above he states that he is going with a Holly. The harness is for a NA engine if you have FI then you need to cut a slot in it so a 2 or 3 bar will work. :steering:
Oh yeah, I thought that was odd.....I don't know how I missed that. Hey Bart! Got nothing to do on a Friday night either, eh? :lol: We should've gone to Duke's drive in or something. 75th and Harlem I believe....ever been there? Lot's of classic and 80's Hot rods there. :cool:
Hey Gene, that has to be the most beautiful chassis/susp. I've ever seen. It's almost too good to take on the road! :eek:
I"M taken mine for a drive tomorrow if I can get it out of the garage. Been reading about how I have no low end torque with my intake so I may have trouble getting it to go. :leaving:
I'm afraid I have to agree. Those tires are over kill too. For your application I don't think you need anything bigger than a 205. :crazy: :smash: :lol:
Have got to take some more recent photos. Just recently plumbed a pump/cooler/filter set-up for the supercharger. Transmission cooler is now plumbed also.
