Hey guys can anybody tell me were the headlight relays are in an 1984 vette passanger side headlight wont go up, might check the relay first :confused:
They're hidden! They're on the front of your driver's side wheel well. Look and you'll see a black plastic cover held on I think by 3 screws with a ton of wires going under it. Take that cover off and you'll find the 3 relays.
Also; if you think it is the relay, swap them. The two that are the same control the left and right side. The third is the isolation relay and controls the motors going down. Switch the two and see if the problem follows the relay. If not, problem is in the headlight.
