Code 13 Oxygen Sensor Circuit (open loop)
Old Jul 16, 2003 | 01:59 AM
pastor's Avatar
pastor
7th Gear
Default Code 13 Oxygen Sensor Circuit (open loop)
I've been trying to deal with this code 13 the past year and can't seem to get to the root of the problem. Oxgen Sensor Circuit in open loop - doesn't seem to effect the performance in any way - but it's annoying to have the check engine light come on and stay on. Any suggestions out there in Corvette land? :banghead:
Old Jul 16, 2003 | 05:33 PM
kittmaster's Avatar
kittmaster
Default Re: Code 13 Oxygen Sensor Circuit (pastor)
check and clean the connector to the O2 sensor. Get a scan tool to see if its even responding or measuring.........if not replacement may be required......or you have a bad ground
