335 Tire on GS Wheels
Old Jul 16, 2003 | 04:50 PM
tkrussell's Avatar
tkrussell
Default 335 Tire on GS Wheels
Will a 335/35-17 Tire on the GS offset 17x11 Wheel fit without rubbing?
Or do you neet the ZR-1 offset wheels?
Thanks. Trying to get just a little more rear rubber.
Old Jul 16, 2003 | 05:05 PM
vvv90's Avatar
vvv90
Default Re: 335 Tire on GS Wheels (tkrussell)
http://forums.corvetteforum.com/zerothread?id=374394
Old Jul 16, 2003 | 05:26 PM
tkrussell's Avatar
tkrussell
Default Re: 335 Tire on GS Wheels (vvv90)
Thanks. Nice picture. Great look.
I've got the GS offset wheels which don't stick out as much as the ZR-1 offset. Will the 335's clear the inner fender well? I'm not worried about the outside. The GS flares cover the tires nicely.
Old Jul 16, 2003 | 06:40 PM
superlund's Avatar
superlund
I posted some pics recently of where my GS 335's rubbed on the inside. Should still be out there somewhere. You can make it work, required some grinding & trimming of the plastic inner fender. Mine also rubbed the trailing arm bracket very lightly. http://forums.corvetteforum.com/zerothread?id=589517
Old Jul 16, 2003 | 07:55 PM
vvv90's Avatar
vvv90
Default Re: 335 Tire on GS Wheels (superlund)
It's too bad they don't sell 335 Drag radials :cry: Or 11.5" A-Molds. :cry: :cry:
Old Jul 16, 2003 | 08:00 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
If you push them in the corners the 315 on my GS cut into the fender liners. 335 is to big for 11" rim to get good performance. I did see a 335 on stock C5 wheels :lol: He wondered why it didn't hold in the corners :rolleyes:
Old Jul 16, 2003 | 08:56 PM
larryfs's Avatar
larryfs
Default Re: 335 Tire on GS Wheels (John Shiels)
>>If you push them in the corners the 315 on my GS cut into the fender liners. <<
was it lowered or stock height?
Old Jul 16, 2003 | 09:34 PM
John Shiels
Default Re: 335 Tire on GS Wheels (larryfs)
stock height with GSC's I did it on the cloverleafs
Old Jul 16, 2003 | 09:45 PM
scorp508's Avatar
scorp508
Get em' widened at a shop.
Old Jul 16, 2003 | 10:14 PM
Darkness's Avatar
Darkness
Default Re: 335 Tire on GS Wheels (scorp508)
I dont know about push and pull effects after but they sure look great :cool:
Old Jul 17, 2003 | 12:41 AM
BAM92's Avatar
BAM92
Default Re: 335 Tire on GS Wheels (Darkness)
:iagree:
Old Jul 17, 2003 | 09:20 AM
larryfs's Avatar
larryfs
Default Re: 315 Tire on GS Wheels (John Shiels)
John,
now you have me worried about doing the 315 kumho's in the rear for driving schools. currently I'm running 275 victor racers all around on my 96. But after these tires are used up, I was buying some GS rims and 315's for the rear.
now you have me 2nd guessing the setup I have seen on quite a few cars.
also I lowered the rear about 1/4" just to level the car. hmmmmmm......
To 335 Tire on GS Wheels
