Coolant temp switch part No
Old Jul 16, 2003 | 08:50 PM
timallard's Avatar
timallard
Default Coolant temp switch part No
I have an 89 L98. I bought one of those Ecklers fan switch upgrades that are supposed to cut the fans in at 190 deg. For some reason it cuts in a lot lower(at the same temp as the old one, about 165). Consequently my main fan is running all the time and doesn't need to be as I have a new heavy duty radiator.
Does anyone have a part No for a true 180 or 190 deg temp switch? Thread size is 3/8 x 18 NPT
Thanks in advance for any help.
Tim
Old Jul 16, 2003 | 10:18 PM
Lionsden's Avatar
Lionsden
Default Re: Coolant temp switch part No (timallard)
I believe on the 89 the main fan is controlled by the ecm. The fan switch (between cyl 1&3) controls the aux fan. If the A/C is on the main fan runs all the time.
Dan
Old Jul 17, 2003 | 12:14 AM
1988C4's Avatar
1988C4
4th Gear
Default Re: Coolant temp switch part No (Dan Plett)
Dan,
I have an 88 coupe with the standard thermostat. Fact is that on hot days, my standard issue radiator at best, maintains my coolant temp at approximately ambient plus 95 to 100 degrees, with a minimum temperature (on cold 40 degree ambient temp days) of 187 degrees. I bought one of those switches, and similarly noticed that once turned on, it never got cool enough to shut off. My car runs cool enough when at highway speeds, but in town on a hot summer day with the AC on I hate to see it cycle from the ECM set point of 228 to 195, so I just put a toggle switch in series with both the secondary and ECM primary fans. (The relay control circuits for both fans just need to "see" a common path to ground to turn on.) I now have the option to not worry about the temperature getting to 228 and run both fans (the auxillary alone does not get the job done) at my descretion, particularly when I know I am in town in the summer, and "mama" is getting in "sweaty need of the AC". Even at that, if it is 100 out and I am sitting in traffic with the AC on, my coolant temp can get to 203 and hold, but not to the 228 that drives me crazy. I am evenbtually going to look into the larger capacity aluminum radiator that Eklers offers ($649) and then perhaps a cooler thermostat (which will also help performance). In any case, enjoy your C4. I just will always be in love with the lines of our cars, they are the best value on the market for my money, and if taken care of properly, will run reliably for us forever!
Regards,
Tom [IMG][/IMG] :cheers:
Old Jul 17, 2003 | 12:17 AM
1988C4's Avatar
1988C4
4th Gear
Tim,
Sorry to have mistaken you as Dan in my reply
Tom :cheers:
Old Jul 17, 2003 | 02:20 AM
vettek50's Avatar
vettek50
ttt....what is the part # and manufacture of the fan switch? who makes it? should be able to buy it at any parts store, but no no no, nobodys heard of it......
seems like these guys can buy it but not us :
not the number that eklers or madvet use! which is 609-106
Old Jul 17, 2003 | 06:39 AM
Lionsden's Avatar
Lionsden
Default Re: Coolant temp switch part No (vettek50)
Fan Switch
GM part # 3053190 ON @ 200'F, OFF @ 185'F
The connector for the switch is P# 121026, if needed
GMPartsdirect
GM LIST: $39.12
OUR PRICE: $19.56
Old Jul 17, 2003 | 03:08 PM
vettek50's Avatar
vettek50
Fan Switch
GMPartsdirect
GM LIST: $39.12
OUR PRICE: $19.56
coververted to
Blue Streak Part # TS-136 on @200, off@185'F
price==33.71Can...
Thaks ...DAN PLETT
To Coolant temp switch part No
