Whats this telling me ?
Old Jul 16, 2003 | 09:17 PM
Beach Bum's Avatar
Beach Bum
Default Whats this telling me ?
I turn my 85 C4 on, and both turn signals and the high lights(brights) lights on the dash all light up solid and stay lit, and the dash bulb itself has gotten dimmer.
Typically when a turn signal light, lights up, it means a taillight is out.... but all of my exterior lights work perfectly.
I'm wondering if I have a short somewhere or if this is another GM signal that something has gone out (Perhaps my dash bulb is done for ?)
Thanks for any input :)
cheers,
Beach Bum
Old Jul 16, 2003 | 09:24 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Whats this telling me ? (Beach Bum)
My '84 has had the same problem from time to time. Actually, it's been awhile. While not technically correct, I ignored the problem and it went away. Good luck, and...
RACE ON!!!
Old Jul 16, 2003 | 09:25 PM
GlennS87's Avatar
GlennS87
I've experienced this also and then it goes back to normal by itself. Unfortunately I have no idea why it's happening.
Old Jul 16, 2003 | 09:40 PM
scorp508's Avatar
scorp508
Default Re: Whats this telling me ? (GlennS87)
Usually thats a ground in the dashboard getting shot and needing to be resoldered.
Old Jul 16, 2003 | 09:47 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: Whats this telling me ? (scorp508)
I had a similar situation and all I had to do is get to the bulbs and wiggle them a little. They just needed a good connection.
Old Jul 16, 2003 | 10:20 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Whats this telling me ? (85vet)
Beach,
My car did this about 2 years ago. It did not do the turn signals and bright light, but it did get dim then bright.
I eventually pulled the entire unit out and replaced every bulb in the dash with new ones even the ones that looked fine...After that its worked fine ...... :smash: on wood!
I would try that and be sure to observe the electrical connectors..sometimes just unplugging them and reconnecting solves the problems.
Hope to find it :cheers:
[Modified by ski_dwn_it, 10:20 PM 7/16/2003]
Old Jul 16, 2003 | 10:29 PM
vader86's Avatar
vader86
:withstupid:
When the 2 turn lights and bright light turns on, there has been a loss of ground somewhere, either in the dash itself or there may be a loose wire in the engine bay near the firewall. The dash then turns these lights on so that its grounded.
For mine, just replacing the 4 bulbs in the dash unit made it go away. But you might have to resolder the unit.
Old Jul 16, 2003 | 10:34 PM
Beach Bum's Avatar
Beach Bum
Default Re: Whats this telling me ? (vader86)
Okay, thanks guys, I'll get into tomorrow and let you guys know what I find.... I hate things like this.
cheers,
Beach
Old Jul 16, 2003 | 10:44 PM
MrNuke's Avatar
MrNuke
:withstupid:
:iagree: As the man said.. Tiem for arebuilt LCD panel possibly.. I did mine 3 years ago and it's been prefect since..
Old Jul 16, 2003 | 11:46 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Whats this telling me ? (MrNuke)
http://www.batee.com/corvette/index.shtml :cheers:
To Whats this telling me ?
