stuck on high idle
Old Jul 18, 2003 | 03:03 PM
atotalnincompoop's Avatar
atotalnincompoop
Default stuck on high idle
yesterday i was having the occasional problem with the car being stuck on high idle, it would last a few minutes and then idle down , today it won't idle down at all, it idles at 1500rpm all the time, any ideas??
thanks Greg :cheers:
Old Jul 18, 2003 | 03:11 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: stuck on high idle (atotalnincompoop)
Clean the IAC and it's bore under the TB; then use the method on my site to reset the IAC & base idle.
Also clean the TB while you're in there.
If that doesn't get the job done, replace the IAC.
Old Jul 18, 2003 | 03:13 PM
atotalnincompoop
Default Re: stuck on high idle (65Z01)
thanks, i'll go to your site now :cheers:
Old Jul 18, 2003 | 09:59 PM
redvette1986's Avatar
redvette1986
In my case, the TPS was the culprit...twice in three years. Ya gotta hate that 1500 rpm idle in traffic on a hot summer day....!
To stuck on high idle
