Clutch worn out???
Old Jul 18, 2003 | 05:55 PM
Bat Man's Avatar
Bat Man
Default Clutch worn out???
Well I dont know if its the clutch or the tranny.
The gear selector can go into gears fine. When In gear, If I let clutch out, it just doesn't do anything. Its just like its there doing nothing. It has pressure, its not dropped to the floor or anything.
Whats up?
Old Jul 18, 2003 | 06:52 PM
bogus's Avatar
bogus
Default Re: Clutch worn out??? (Valleybacker)
that sounds like the clutch... if it was the tranny, it would be a real mess. all sorts of ugly noises.
I would not bet against the clutch fork being brnt or broken.
What year is your vette?
Old Jul 19, 2003 | 12:55 AM
Bat Man's Avatar
Bat Man
Default Re: Clutch worn out??? (bogus)
Its a 92, so its a ZF. So I don't think its the tranny, those things are rock solid.
Old Jul 19, 2003 | 11:16 AM
Bat Man's Avatar
Bat Man
ttt
Old Jul 19, 2003 | 11:21 AM
bogus's Avatar
bogus
absolutely, so is mine!
I would check into the clutch... it sounds like something has really take a crap in the clutch area... could even be the flywheel... yes... the flywheel.
They are what is called "dual mass". hence, there are 2 separate masses of metal, interconnected with a rubber bond. the rubber acts like the springs in a friction disc.
The rubber can break down, especially when exposed to engine oil. that could also be the problem... I hope not. dual mass flywheels are not servicable - you cannot repair them, nor can you resurface them....
good luck, and keep us posted.
Old Jul 20, 2003 | 12:14 AM
Bat Man's Avatar
Bat Man
Thanks bogus, the auto repair place said they can get to it monday maybe tuesday. I'm a little nervous as i've never had anywork on a corvette done there. Except for i got the car inspected there.
To Clutch worn out???
