Supercharging a stock LT-1
Old Jul 19, 2003 | 01:07 AM
C4kid94's Avatar
C4kid94
Default Supercharging a stock LT-1
Can you supercharge a stock LT-1 egine without getting new internals with out having problems. And if possible at what psi. thanks for your help
Old Jul 19, 2003 | 01:21 PM
krivera's Avatar
krivera
Default Re: Supercharging a stock LT-1 (C4kid94)
At your location you should be fine with 6 psi and yes it is possible to run a blower with a stock LT-1 but i would say 6psi you would be fine just get a really good intercooler to keep the intake temp down :D
Old Jul 19, 2003 | 05:54 PM
C4kid94's Avatar
C4kid94
Default Re: Supercharging a stock LT-1 (krivera)
thanks for the help. But ive heard the egine will only last for 10,000 miles or so with stock internals. what kind of life span can i expect if I run 6 psi
Old Jul 19, 2003 | 08:45 PM
BAM92's Avatar
BAM92
I am sure that depends on how well your set up is tuned and how big your right foot is.
Old Jul 21, 2003 | 12:10 PM
vvv90's Avatar
vvv90
It would benefit you from doing a search in the archives about this topic. It's been done a thousand times and no one is going to want to explain themselve again and again. I don't say that to be rude, it's just the way it is.
1.) You can run 8psi of intercooled boost safely.
2.) It would benefit you to hang around and learn how boosted cars work and what makes them break, i.e. detonation.
3.) Depending on how well you tune and monitor your engine, your engine will last as long as it would otherwise stock. Daily driven the supercharger doesn't kick in until around 3,000RPM. So basically it's stock up until 3500RPM.
Old Jul 31, 2003 | 12:27 PM
vetteheadracer's Avatar
vetteheadracer
2022 C7 of the Year Finalist - Unmodified
Also depends on the mileage on the motor prior to fitting.
Mine had 50,000 prior to fitting and it lasted about 10,000 before it started to eat the pistons. The extra power trashed the clutch in 600 miles, so went for a Centreforce.
Old Jul 31, 2003 | 03:34 PM
Bruce's Avatar
Bruce
Default Re: Supercharging a stock LT-1 (vetteheadracer)
The magic word is tuned. I have seen stock LT1 with 7psi intercooled, headers tuned on dynoed resulted 405rwhp last about 16000 miles and 60+ passes at the track. Also, how long it last depends how your car tuned and how you drive. Another note, if your walet are not full then don't get into supercharging LT1 car. Cause it eventually will cost you big $ for all sort of things.
Bruce
93LT1 Conv w/ZF6
Blown D1-SC/N2O
ARE built 383ci/Stage II heads
Bruce
[Modified by Bruce, 2:36 PM 7/31/2003]
Old Jul 31, 2003 | 09:50 PM
black bart's Avatar
black bart
Default Re: Supercharging a stock LT-1 (vvv90)
:iagree: :yesnod: :yesnod: :leaving:
To Supercharging a stock LT-1
