Hurst Roll Control Install
Old Jul 19, 2003 | 03:35 PM
rcolling's Avatar
rcolling
Default Hurst Roll Control Install
I just finished the install of the Hurst Roll control unit on my '96 to help heat up my new DRs.
I documented the install.
Let me know what you think of the installation instructions. I know they would have saved me several hours of looking where to install it, 4 trips back and forth to the parts store because I didn't have the correct parts.
http://rcolling.dns2go.com/rollcontrol/index.htm
Old Jul 20, 2003 | 11:36 AM
silver & red CE's Avatar
silver & red CE
Default Re: Hurst Roll Control Install (rcolling)
Looks great, I'm getting ready to install a line lock and I was under the impression I'd need to cut lines, you show how to do it without cutting. I saved your web pages on disc, it's too good to lose.
Eric
Old Jul 20, 2003 | 06:26 PM
Tony.96LT4's Avatar
Tony.96LT4
Nice job! I installed mine under the ECM as well but bolted it to a bracket that I made and bolted that to the mastercylinder. I had to splice the linelock line under the car(less noticable). Did you have a ball flare into the MC? from the picture I couldn't tell. I got my extra lines at the junkyard and just cleaned them up. Good tip on bleeding the brakes. I put all fresh in mine since I was there. :lol:
Old Jul 20, 2003 | 06:37 PM
rcolling's Avatar
rcolling
Default Re: Hurst Roll Control Install (Tony.96LT4)
No. There is an aircraft supply place out by the Ontario, CA airport that has become quite the spot for getting parts like this for car restorers/hot rodders.
He said I did not need a bubble flare to go into the MC but I did need the bubble flare connector so that the line that I disconnected from the MC will not leak.
So far, no leaks...
To Hurst Roll Control Install
