strange error message "SYS"
Old Jul 20, 2003 | 06:40 PM
nottheliving's Avatar
nottheliving
Default strange error message "SYS"
recently my c4 has been giving me a strange error message where it usually displays my range, avg mpg, and current mpg.......does anyone know what it means ? it flashes on and off and says "SYS" thanks for your help
Old Jul 20, 2003 | 06:43 PM
robert kirk's Avatar
robert kirk
Default Re: strange error message "SYS" (nottheliving)
My 92 did the same thing. Drove me nuts looking for it. Turned out to be the ecm. Bought a rebuilt unit from GM. cheers robert
Old Jul 20, 2003 | 06:45 PM
nottheliving
Default Re: strange error message "SYS" (robert kirk)
it did the same exact thing? jeez.....did u ever find out what the dang thing meant? cuz i swear to god, its drivin me nuts
Old Jul 20, 2003 | 06:57 PM
LT4 2 Fast's Avatar
LT4 2 Fast
I noticed that on my display last week after my oil change. It came on after the car was started a few times, but I haven't seen it since. I too would like to know what it meant.
Old Jul 20, 2003 | 06:58 PM
robert kirk
I first bought a factory service manual. I spent about 2 1/2 months going step by step and it was driving me crazy. Finally i called the chevy dealer to see what they did and the answer i got was "start changing parts in the order of the manual and you will sooner or later track it down." That may be fine for a chevy dealer who has access to parts he can put back in the box, but for me it is pretty expensive. After about 800 dollars in modules, switches, etc, i was down to the ecm. Fixed the problem. Up side to this is all the under hood electronics are new. This was a serious pita. robert
Old Jul 20, 2003 | 07:02 PM
don hall's Avatar
don hall
http://www.c4vettes.com/ecm.htm
Old Jul 20, 2003 | 07:06 PM
nottheliving
Default Re: strange error message "SYS" (Oldman)
so your saying i need to buy a ecm to fix this annoying little thing?....how much do they cost?
Old Jul 20, 2003 | 09:51 PM
AS84's Avatar
AS84
My 90 will do this too. I have two different chips that I run in my car. One my buddy made and one from fastchip. The one from Fastchip won't flash the sys but the one my buddy made will. It is definately ecm related. Does it by chance have an aftermarket chip in it. By the way.....it only happends periodically right??
Old Jul 20, 2003 | 10:03 PM
MTVette's Avatar
MTVette
Default Re: strange error message "SYS" (AS84)
Check your battery first. My 92 did this whenever I started it up with a nearly discharged battery. Replacing the battery also ended teh flashing SYS.
Old Jul 20, 2003 | 10:17 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
The SYS indicates the CCM (not the ECM, engine control module) has detected a fault. Two of the most common reasons are the CCM has seen the ignition voltage out of range(usaully just a battery going) or the radio head unit has been changed to an aftermarket unit that has a different resistance in the backlight dimmer circuit which the CCM takes to be an error(which can be fixed easily).There are a few other things that can set the SYS, but they don't effect the engine. I"ll try and remember to post the procedure for pulling the CCM codes when I get home from work. :steering:
Old Jul 21, 2003 | 01:55 AM
Ramrod92's Avatar
Ramrod92
Default Re: strange error message "SYS" (Ramrod92)
Ok, this is long. First ground pin G of the ALDL connector. You can do this by using the paper clip from G to A (which is the ground) Turn the key on, but do not start. The CCM will display any fault codes in sequence using the digital speedometer area. In smaller numbers just below these readouts it will also display the module for which they apply. The CCM is module 1, the ECM is module 4, the ABS/ASR EBCM is module 9. Post which fault codes are present and we'll try to explain them. If you plan on doing much work on your car I would strongly suggest you obtain a copy of the Helms service manual for your model. http://www.helminc.com/helm/product2...7681ACABCHE7XD
Old Jul 21, 2003 | 07:34 AM
Atok's Avatar
Atok
:iagree: Clearly documented in the GM Service Manual. SYS indicates a code stored in the CCM.
:cheers:
Old Jul 21, 2003 | 08:11 AM
NotSlo's Avatar
NotSlo
Elite Member
Cruise-In III Veteran
St. Jude Donor '09
Default Re: strange error message "SYS" (MTVette)
Same thing here. Battery was dying. :iagree:
Old Jul 21, 2003 | 09:07 AM
silver & red CE's Avatar
silver & red CE
Mine does this when I've stored the car for 3-4 weeks (in the winter). It goes away after I drive it for 30 minutes, I always assumed it was low battery.
Eric
To strange error message "SYS"
