How do I convert to an external coil distributor?
Old Jul 20, 2003 | 07:32 PM
LD85's Avatar
LD85
Default How do I convert to an external coil distributor?
Whay you ask?,,,, my new engine needs to have decent spark to 6000RPM and my exsisting stuff needs to be replaced for the new 406 engine.
Is my HEI satisfactory for 6000 RPM, I will then just buy a new HEI module & coil like a HEI rebuild kit. But eventually, next spring, I will go with an MSD 6AL, but need to replace my stock internals or buy a new distributor.
How do I swap over to an external coil PROS & CONS , just buy the distributor new or go to the junk yard and for what model year do I get one, Camaro etc?
What are the wirring issues?
TIA
Old Jul 20, 2003 | 07:49 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: How do I convert to an external coil distributor? (ld85)
Check into a HyperTech coil/cap/rotor as it will produce good spark much higher than the stock HEI and is a direct bolt-on.
Ask the Tech guys at Summit or HyperTech if it will do the job up there.
Old Jul 20, 2003 | 09:48 PM
AS84's Avatar
AS84
Default Re: How do I convert to an external coil distributor? (65Z01)
I have the hypertech cap, coil, and rotor. I can't say nothing bad about it. But then again I shift at 5400.
Old Jul 21, 2003 | 10:22 AM
LD85's Avatar
LD85
Default Re: How do I convert to an external coil distributor? (AS84)
so I guess I will just rebuild my stocker with upgraded parts :seeya
Old Jul 21, 2003 | 08:49 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: Not sure if I am helping, but Gm HEI is the strongest spark available
One of the things GM did correctly
:seeya
:steering:
Old Jul 21, 2003 | 09:08 PM
scorp508's Avatar
scorp508
I've got an MSD coil and MSD low resistance bushing in my distributor, no loss of spark or power at 6300. :cheers:
I've also got an MSD Digital 6+ box, but it isn't hooked up right now.
To How do I convert to an external coil distributor?
