Does C5 Brake Conversion affect C4 ABS System?
Old Jul 20, 2003 | 08:04 PM
1990PoloVette's Avatar
1990PoloVette
Default Does C5 Brake Conversion affect C4 ABS System?
I'm not sure If I ever read anything about this?? I'm not sure exactly how the ABS works (sensors, computer, ect) so thought I'd ask. I'll be doing the conversion on a 1990.
Old Jul 20, 2003 | 08:32 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Does C5 Brake Conversion affect C4 ABS System? (1990PoloVette)
:cheers: Short answer...NO!
ABS system senses wheel lock up independent of the roters or calipers and modulates pressure (barke fluid) applied to each wheel!
ABS works by sensors in the whele/bearing assembly, not the brakes!
ABS will work fine with C5 conversion
:seeya :steering:
[Modified by jackdaroofer, 8:36 PM 7/20/2003]
Old Jul 20, 2003 | 08:57 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: Does C5 Brake Conversion affect C4 ABS System? (jackdaroofer)
Jack is dead on, as usual. The ABS system is run by sensors and fluid, not the hardware (rotors, calipers, brackets, etc). The hardware would have no way of knowing the difference.
:steering:
Old Jul 20, 2003 | 09:30 PM
black bart's Avatar
black bart
Default Re: Does C5 Brake Conversion affect C4 ABS System? (edsalinas)
While your at it get the spring from drm and install it in the master cylinder makes the back brakes better.
Old Jul 21, 2003 | 08:54 AM
kittmaster's Avatar
kittmaster
[QUOTE]Short answer...NO!
:withstupid:
Old Jul 21, 2003 | 08:43 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Default Re: Does C5 Brake Conversion affect C4 ABS System? (black bart)
:cheers: I have C5 conversions on front and DRM spring in proportioniong valve
Stopping is awesome
But now I have to spend as much time cleaning the brake dust off the rear wheels as I used to have to do on just the fronts :jester
:seeya
:steering:
Old Jul 21, 2003 | 08:49 PM
edsalinas's Avatar
edsalinas
............ But now I have to spend as much time cleaning the brake dust off the rear wheels as I used to have to do on just the fronts :jester
:steering:
Jack, you are a funny guy.
No pain, no gain........
:lolg: :lolg: :lolg: :lolg:
Old Jul 21, 2003 | 09:09 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
:cheers: I appologize Ed!
I don't mean to be :blueangel:
Maybe it is the Alzheimers setting in! :blueangel:
Did you get wheel info from Caboboy?
:seeya
:steering:
[Modified by jackdaroofer, 9:11 PM 7/21/2003]
Old Jul 21, 2003 | 09:26 PM
edsalinas's Avatar
edsalinas
........... I don't mean to be :blueangel:
Maybe it is the Alzheimers setting in! (You aient that old bro). Did you get wheel info from Caboboy?
:seeya
:steering:
No, he's in, guess where.......
But I will........
GLYJ........
Old Jul 22, 2003 | 07:30 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Ed
You have mail
Jack
To Does C5 Brake Conversion affect C4 ABS System?
