Wheel performance question
Old Jul 21, 2003 | 12:18 AM
VetteNoob's Avatar
VetteNoob
Default Wheel performance question
How much difference does 2 lbs make per wheel in relations to performance?
My dilema.
I have a set of A-molds coming that I'm 99.5% sure are made by Performance Wheels. I've been told they are about 2 lbs lighter than the AFS wheels I just won on eBay. The AFS wheels have the 11" rear wheels. They are cosmetically not identical from what I understand, plus AFS silver wheels no longer have the machined lip like they used to. Im planning on selling one set.
Which set should I sell? I will definitely sell of of the sets since I dont need 2 set of wheels....or do I?
Just curious as to what you guys think about rotating mass and stuff.
Thanks!@
Old Jul 21, 2003 | 02:19 AM
Slalom4me's Avatar
Slalom4me
Default Re: Wheel performance question (VetteNoob)
2 lb/wheel is 8 lbs total of rotating inertia. This would be equivalent
to perhaps 3 fwhp on a 3,000 lb vehicle.
In considering where to focus your effort and cash in a weight loss
program, reducing components that rotate at axle speed produces
about 3 times the benefit that comes from shedding non-rotating
weight. Reducing componants that rotate at engine speed produces
15 times the benefit.
In Chp 15 of "Chassis Engineering" (HPBooks #1055, 1993) Herb
Adams gives examples of the effective fwhp gain derived from
chopping 15 lbs off a 3,000 lb car with 428 fwhp:
Chassis = +2.1 fwhp
Axle speed = +6.4 fwhp
Eng speed = +32.1 fwhp
My dilema.
I'm planning on selling one set.
Don'tmake any decisions until you weigh the wheels yourself. For some
reason, wheel weight info seems to be unreliable. Once you know weights
for certain, if there really is only 2 lbs difference then just keep the ones
you like the most. (If this happens to be the heavier of the two sets, use
helium to inflate them and you'll never know the difference.)
[Modified by Slalom4me, 1:24 AM 7/21/2003]
Old Jul 21, 2003 | 03:06 AM
TIMSPEED's Avatar
TIMSPEED
Default Re: Wheel performance question (Slalom4me)
Don't make any decisions until you weigh the wheels yourself. For some reason, wheel weight info seems to be unreliable.
The info he got was pretty reliable. ;) Also, I'd like to say, sell the AFS's :D
Old Jul 21, 2003 | 08:38 AM
vader86's Avatar
vader86
Default Re: Wheel performance question (TIMSPEED)
2lbs is nothing, just make sure they look good.
Id keep both if you can afford it, use one set for autox/drag/road racing.
Old Jul 21, 2003 | 04:17 PM
NavyVet's Avatar
NavyVet
Good info from Slalom4me. I suggest you weigh your wheels before deciding which to sell, if any. AFS, like many vendors of A-mold copies, has changed manufacturers several times. Over time - Japan, USA, China, etc. The result is differing weights. I have two sets (8 wheels) of AFS 11-inchers. One set has wheels 1.5 pounds lighter - two different manufacturers. :flag
Old Jul 21, 2003 | 04:32 PM
VetteNoob's Avatar
VetteNoob
Thanks for the feedback guys.
So you can really use helium to inflate your tires? Will it really make that much difference? Is it worth the time and effort? Same PSI? Arent the helium molecules smaller than the molecules in the air we breathe and thus tend to leak out faster from the tires?
Oh dang...chemistry.
I may try to keep both sets, but then again...you may see some 5 spokes popping up in the 4sale section in the near future.
Old Jul 21, 2003 | 08:12 PM
Slalom4me's Avatar
Slalom4me
that much difference? Is it worth the time and effort? Same PSI? Aren't
I think if there is a drawback, it is how people can't help laughing
when they hear helium-filled tires spin. The unusual sound cracks
'em up everytime.
<disengaging fertilizer-dispenser now...>
Old Jul 21, 2003 | 10:45 PM
VetteNoob's Avatar
VetteNoob
:banghead:
Should have known better to even think it was serious. *I'm it*
:lol:
Old Jul 21, 2003 | 11:27 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
How much more do the 315s weigh than the stock tires?
Old Jul 21, 2003 | 11:36 PM
tempest's Avatar
tempest
... For some reason, wheel weight info seems to be unreliable
one of the reasons why i think wheel weight info is unreliable is because WHERE the weight (mass actually) is distributed on the wheel has more effect than the amount of the mass itself. in general, the further the mass is from the axis of rotation, the "heavier" the inertia becomes. the effect of the distance from the axis has a power of FOUR!!!
i don't think many wheel manufacturers could easily tell you the rotational inertia of their wheel, but it certainly would be the most objective way to measure how "heavy" a wheel is.
also to keep in mind that a wheel must not only be light, but it must be strong as well. the loads our wheels take can be huge and distort them more than we think.
Old Jul 22, 2003 | 01:54 AM
Slalom4me's Avatar
Slalom4me
Default Re: Wheel performance question (tempest)
is because WHERE the weight (mass actually) is distributed ...
I meant that static weights seem unreliable - what people are told a
wheel will scale at turns out to be at variance with what they see for
themselves. But I agree with everything else you say.
[Modified by Slalom4me, 12:54 AM 7/22/2003]
To Wheel performance question
