What viscosities do you use??
Old Jul 21, 2003 | 01:15 AM
Alex D's Avatar
Alex D
Default What viscosities do you use??
Intersted what motor oil viscosities you are using........
Old Jul 21, 2003 | 01:45 AM
hngacurv's Avatar
hngacurv
Default Re: What viscosities do you use?? (Alex D)
5W-30 here.
Old Jul 21, 2003 | 10:02 AM
Strick's Avatar
Strick
!0W-30 in the summer just like the manual says "may be used" at temps above 0.
Old Jul 21, 2003 | 08:29 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: What viscosities do you use?? (Strick)
:cheers: I have been running AMZOIL RACING GOLD 20w/50 for past 5 years
Oil pressure never drops below 50 at idle when very hot
Running around the mountains, as I like to do, oil temp goes through a 40 degree temp swing, that's why I like this oil!
Plus, seeing low oil pressures scares the h%^l out of me :eek:
It's pricey, around $ 8 per quart
:blueangel: :seeya
:steering:
Old Jul 21, 2003 | 10:44 PM
Ray Vargo's Avatar
Ray Vargo
Default Re: What viscosities do you use?? (hngacurv)
0w40 in my 396 it has 23 psi at idel & 70 psi at 7000 with a stock pump Z 28
spring .0029 on the rods .003 on the mains used 1 pt of oil in 6800 miles
& ya can't beat that. :) :) :)
Old Jul 23, 2003 | 05:27 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Mobil 1 ..10/30...it never gets real cold here in Florida... :D
Old Jul 23, 2003 | 05:29 PM
scorp508's Avatar
scorp508
10W30 year round.
Old Jul 23, 2003 | 06:52 PM
Beach Dude's Avatar
Beach Dude
20- 50 castrol. always had good luck.
1991 gmc pu before I sold it 238,000 miles, never been apart.
1988 Corvette, 123,000 miles still going strong.
I had a Grand National, used mobile 1, no problems.
I think that doing a regular maintenance is the key. I change approx every 2500 miles. Blood of the engine. :chevy
Old Jul 23, 2003 | 07:12 PM
Rick92's Avatar
Rick92
10 w 30 here :cheers:
Old Jul 24, 2003 | 07:29 AM
Red Tornado's Avatar
Red Tornado
10w30 all year, here is Pennsylvania.
Old Jul 24, 2003 | 09:48 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
10/30 synthetic :cheers:
Old Jul 24, 2003 | 05:34 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Cool months....10w/40w Valvoline Max Life...
Warm/Hot months....20w/50w Valvoline Max Life....Southern CA.
My '84 has just over 87k miles on it......runs great...and with the Max Life the small oil leaks have gone away.....go figure...
tony
:flag :flag :flag :flag
Old Jul 24, 2003 | 10:39 PM
bstirn's Avatar
bstirn
5/30 mobil 1 year round [IMG][/IMG] :chevy
Old Jul 25, 2003 | 01:56 AM
R23HTC's Avatar
R23HTC
Default Re: What viscosities do you use?? (bstirn)
10w30 Mobil 1. :yesnod:
Old Jul 25, 2003 | 02:52 PM
montie98's Avatar
montie98
Default Re: What viscosities do you use?? (R94 LT 1)
Why in my 85 owners manual does it say DO NOT USE 10W40 OIL?
Old Aug 4, 2003 | 05:09 AM
Swede's Avatar
Swede
Default Re: What viscosities do you use?? (montie98)
Hello!!
I am running straight 30 Oil (Penzoil) , Ít has allways worked in our TAD Dragster. It takes out a little noice from my RR so the PITA, KS is not drawing me back. :chevy
Old Aug 4, 2003 | 07:52 PM
JCAIRE2's Avatar
JCAIRE2
10/30 mobil1 :cheers:
To What viscosities do you use??
Old Aug 4, 2003 | 09:00 PM
J Z06's Avatar
J Z06
10W40 quaker state year round.
Old Aug 4, 2003 | 09:37 PM
Ray Vargo's Avatar
Ray Vargo
Odd that I'm the only guy using 0/w40 but then I'm probley the only guy who has his oiling syteam working perfectly! :cool:
Old Aug 4, 2003 | 11:21 PM
pascualjr's Avatar
pascualjr
Default Re: What viscosities do you use?? (AGENT 86)
10w-30 Castrol here. :party:
