Valve springs
Old Jul 22, 2003 | 07:45 AM
Sliding's Avatar
Sliding
Default Valve springs
I received larger ( really big difference from stock ) valve springs with LPE 219 cam.
I remember from one post that somebody said that these springs will require
machining of heads.
I have tried and outside diameter will fit ( close but fit ) stock valve spring seats.
Do I still require machining of heads ( to go deeper with seats ) or is machining only
required to fit outside diameter?
[Modified by Sliding, 1:45 PM 7/22/2003]
Old Jul 22, 2003 | 05:30 PM
1MoorTym's Avatar
1MoorTym
Default Re: Valve springs (Sliding)
:nonod:
or is machining only required to fit outside diameter? )
:yesnod: You're good to go !
Old Jul 25, 2003 | 09:06 AM
Sliding's Avatar
Sliding
Default Re: Valve springs (1MoorTym)
Thank You! :chevy
To Valve springs
