custom chip and injectors
Old Jul 22, 2003 | 05:31 PM
6spd's Avatar
6spd
Default custom chip and injectors
hi, i hope someone can help with my question? i have a 91 vette the custom chip i ordered is being burnt for 24# injectors and other things i still have the factory injectors in the car can i use the chip with the stockers i.m not ready to install the injectors yet ? thanks
Old Jul 23, 2003 | 11:16 AM
dgoodhue's Avatar
dgoodhue
Default Re: custom chip and injectors (6spd)
It should be close enough (24 vs 22), you may want to lower the Fp a little... If you have access to a scan tool just make sure your BLM are all at 108 when driving around.
Old Jul 23, 2003 | 11:39 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: custom chip and injectors (dgoodhue)
:skep: What? :confused:
You mean 128 not 108 right?
I don't think lowering the pressure will get you by. The car will run and probably be oK at part throttle, although throttle responce etc will suffer greatly. A WOT you will be pig rich and probably loose 30-40 HP and blow black smoke out the back of the car like a chimney.
Old Jul 23, 2003 | 02:02 PM
dgoodhue's Avatar
dgoodhue
Default Re: custom chip and injectors (ski_dwn_it)
I meant to say NOT at 108 or maybe I should have said higher than 108. I am not sure there is enough adjustability in the Fuel to have the 24lbs at 128 BLM's.
Old Jul 23, 2003 | 03:30 PM
6spd's Avatar
6spd
okay thanks thats what i thought
To custom chip and injectors
