HELP! check engine light
Old Jul 22, 2003 | 09:32 PM
swoosh's Avatar
swoosh
Default HELP! check engine light
I'm in the middle of flushing my coolant system on my 96 LT1. I had disconnected my MAF sensor and some other sensor right next to it on the air intake hose to give me more space to work with. I also pulled both knock sensors to get a good flush. I connected everything back together but I forgot to connect the MAF sensor. When I turned the engine on, the SERVICE ENGINE SOON light came on!!! I reconnected the MAF sensor and re-started the engine. The light is still on :banghead: What went wrong??? Also, I had dropped the knock sensor in a bucket of coolant :banghead: Is the knock sensor bad now???? Please help!!
Old Jul 22, 2003 | 09:43 PM
don hall's Avatar
don hall
Default Re: HELP! check engine light (swoosh)
http://www.c4vettes.com/ecm.htm
Old Jul 22, 2003 | 10:04 PM
satyr7777's Avatar
satyr7777
Default Re: HELP! check engine light (Oldman)
Sounds like u need to clear the code....
To HELP! check engine light
