Supercharger?
Yes, the supercharger kits are bolt on. If you do it yourself expect 20-30 hours or more for the install. Check out http://www.vortechsuperchargers.com and look up the support pages for PDF on how to do the install to get a good idea what's involved.
As a general info, is it worth it? Yes and no. Depends on how much you want to follow through with the other upgrades needed. I.e. Fuel pump, injectors, ignition timing box, pistons, build up engine. And what you put your HP at. For stock motor and stock 6psi boost, I don't think it's worth $5k for the additional 100HP. There are cheaper alternatives for power. If you build up your motor and get 500+ HP out of it, then it may be worth the money (~$10k) required to do so.
On a stock motor don't expect to run more than 6 PSI. That should give you an additional 75-100 HP at the engine (even though everyone claims 125-150HP). If you run more boost expect to rebuild your motor. Also don't abuse the engine or you'll need a rebuild.
Good luck and check out the C4 - Forced Induction forum for more info.
[Modified by XTwinTurbo, 11:52 PM 7/22/2003]
[Modified by XTwinTurbo, 11:53 PM 7/22/2003]
Raj, I see on your sig that it says you got a hurst shifter. Thinking of getting one too....is it a shorter throw? Is the shifter shorter in lenght? How does it feel? Is it worth spending money on?
[Modified by KouKou, 11:15 AM 7/23/2003]
The only down side was the install. I had mine done by the shop that did the clutch but they mentioned that it took some time to install even with the tranny out of the car.
Need to change the pistons (stock ones don't like boost), drop compression, build up the bottom end (bearings, possibly crank, rods). Add to that additional fuel pump (high flow), larger injectors and ignition upgrade (wires, ignition box and coil).
Some others may have different suggestions.
:skep:
I give, is this a GA sign? :skep:
Is that a frequent tornado warning??? What is there a trailer park out there?
Are turbos more efficient? For HP they are, but not for torque. :yesnod:
My point is, if you want 500HP, it's easier to put a blower on. If you want 1300HP, the turbo app will be more streetable because who needs more than 800RWTQ on drag radials anyway?
[Modified by vvv90, 4:53 PM 7/23/2003]
QUOTE]
Umm, I disagree with that, If you dont believe That Turbos make Huge Amounts of TQ ( When built properly) Check this out http://www.twinturbovette.net/Updates.html I can see how expensive a custom TT setup would be considered the time it takes and charge for labor, unless one has fabrication skills, then I think it would be cheaper to do it that way instead of a SUpercharger.
:nonod:
Turbos make TQ.
montys car makes 1000 TQ and 1200 HP.
It all depends on your application. Do you want the biggest and baddest street machine and money is no object? THEN GO TURBO!
If you want 600HP and you want it as cheap as you can get it? GO SUPERCHARGER!
Are you a street racer or highway guy? GO TURBO!
Are you a drag racer and need good 60ft times? GO SUPERCHARGER!
You guys have to factor in the cost of the time and engineering involved. If there was a text book way of turbocharging a C4 and out of pocket expenses were competetive to supercharging, I probably would have gone turbo. But as it stands I can get more parts, knowledge, and HP out of a supercharged C4 than a turbocharged one related to time and money.
While Monty's car is great! It's also one of a kind. That in and of itself is awesome, but it makes for a lengthy, costly, and downright frustrating experience when you're looking for streetable HP.
I hope I made a clear point for this thread. :seeya:
vvv90, since I assume you have a TPI unit on your car, what else did you do to get a stronger baseline before supercharging? Did you port the intake base, runners and plenum or something? DOes that really add good HP? What if I was to port the whole thing, and then swap the heads out for better flowing ones but still keep it at 9.1 and ram 8psi boost down its throat? :confused:
