TPS Voltage @ WOT
Old Jul 23, 2003 | 08:19 AM
okinawa86vette's Avatar
okinawa86vette
Default TPS Voltage @ WOT
I was adjusting my TPS sensor on my 88 L98 yesterday and noticed that my scan tool was only showing about 3.85 volts for wide open throttle. I adjusted the TV cable a bit and got a hair more travel and it now shows 4.33 volts @ WOT. Going by my handy dandy GM shop manual, it seems like it should be 5 volts at WOT.
My throttle blades look like they are opening completely, so there's not a throttle stickage, although there is a small, maybe 1/16" of play in the throttle cable.
Is that voltage normal for wide open throttle or is it time to replace the TPS sensor? Is there a way to adjust the play out of the throttle cable?
TIA
Chris
Old Jul 23, 2003 | 09:50 AM
scorp508's Avatar
scorp508
Default Re: TPS Voltage @ WOT (okinawa86vette)
You'll never get a full 5 volts at WOT. :) Its hard as hell to get that and also a good idle setting. With that said from the factory you only really need about 69% for the car's ECM to go into WOT mode. That is only 3.45v on the TPS.
Old Jul 23, 2003 | 11:35 AM
STL94LT1's Avatar
STL94LT1
Default Re: TPS Voltage @ WOT (scorp508)
:iagree: My car was getting 3.5v @ WOT and was running fine. I was able to adjust the TPS to 4.07v and there was no performance improvements.
Old Jul 23, 2003 | 03:34 PM
VMAX451's Avatar
VMAX451
Default Re: TPS Voltage @ WOT (STL94LT1)
:iagree: :iagree:
Stock mine was only 3.8, with an aftermarket TB after adjusting it to the proper idle voltage it shows around 4.2. In both cases, a scanner showed that both values translated to 100% throttle angle.
Old Jul 23, 2003 | 05:46 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
My '88 GM Shop Manual was also a little misleading on that issue.
If you set base idle (450rpm) TPS at .65Vdc you can likely get a little more voltage at WOT setting.
The advantage of a higher TPS reading is that the ECM will see WOT earlier and even at part throttle it will see more throttle position so will give more spark advance as well as more fuel (when accelerating).
Old Jul 23, 2003 | 07:09 PM
BBA's Avatar
BBA
Default Re: TPS Voltage @ WOT (65Z01)
If the TPS EVER goes above 4.5V, it sets a code 21 and the car goes into limp home mode.
If the idle voltage goes above .45V, the ecm will think the throttle is opened and will not put the motor in idle mode. You will have an artificially high idle speed.
Old Jul 23, 2003 | 07:18 PM
scorp508's Avatar
scorp508
Default Re: TPS Voltage @ WOT (BBA)
Hmm? Stock idle setting is .54v and you can go as high as .68v under 1100 RPM before setting a code.
Old Jul 23, 2003 | 07:23 PM
VMAX451's Avatar
VMAX451
Mine was .65 at idle, direct from the factory, no codes. The limits depend on the year of the car, it wasn't the same for all C4's.
okinawa86vette
Alright, cool. That's what I wanted to hear. Thank you guys.
Chris
Old Jul 23, 2003 | 08:10 PM
LD85's Avatar
LD85
Mine is set at .57 at idle with the max of 4.4 at WOT and my 1985 GM manual says a max of 4.5V
[Modified by ld85, 8:11 PM 7/23/2003]
Old Jul 23, 2003 | 08:37 PM
Lone Ranger's Avatar
Lone Ranger
Default Re: TPS Voltage @ WOT (Vince Ivanc)
:iagree: :iagree:
The LT1 and LT4 reads TPS voltage more liberally for WOT than L98's did, it can be as low as 3.6 or 3.7v and still translate to 100%. The ECM learns the voltage range from idle to WOT.
Old Jul 23, 2003 | 10:49 PM
BBA's Avatar
BBA
My 87 with 2.59 gear stock TPS was .400 as measured by my Fluke 77B.
If I adjusted it higher, at about .45v, the ecm went into >2%throttle mode and, IAC went open and idle speed went up to 800 RPM, as opposed to teh normal 550 RPM.
Maybe your ECM is calibrated differently?
I do know the 4.5v upper limit will set a TPS failure code in an 87. I saw that this afternoon (had to buy a new sensor).
Old Jul 23, 2003 | 11:13 PM
okinawa86vette
Mine was set at .56V which is well within the shop manual's .54 +/-.08V, but I adjusted it to .62V and noticed better throttle response. Either way, the WOT voltages were between 4.0 and 4.25. As long as the computer recognizes that as WOT and doesn't throw a code, I'm happy. I know the throttle blades are open all the way, I just wanted to make sure the computer was giving the right fuel amount.
Thanks for all the input, everyone.
Once again the Forum helped out.
Chris
To TPS Voltage @ WOT
