Speedo Correction Gears???
Old Jul 23, 2003 | 06:33 PM
Dougs 90's Avatar
Dougs 90
Default Speedo Correction Gears???
I have done a search and havent found quite what I am looking for. I have a Dana 44 with 3.55's and need to put the correction gears when I get the tranny rebuilt. I have seen a list or a calculator somewhere but now can't find it. I lookd at this one:http://www.corvetteforum.net/c4/vettenuts//SpeedometerGearshtm.shtml
It is going into my 1990 automatic. Should I just go with grey and purple? Anyone have the part # for the clips?
Thanks,
Doug
Old Jul 23, 2003 | 07:59 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Speedo Correction Gears??? (Dougs 90)
This is what I used on my '93 with 4L60(not "E") and Dana 44 with 3.45 gears
25513050 and 8642620
and a new sensor 10456089
Old Jul 23, 2003 | 09:30 PM
CFI-EFI's Avatar
CFI-EFI
I can look that up for you. What tire size are you running? I'll never make THAT mistake, again. The clip for the drive gear is a 6261781.
RACE ON!!!
Old Jul 23, 2003 | 10:47 PM
Dougs 90's Avatar
Dougs 90
Default Re: Speedo Correction Gears??? (CFI-EFI)
I run 275/35/18
Thanks,
Doug
Old Jul 24, 2003 | 01:54 PM
Dougs 90's Avatar
Dougs 90
ttt
Old Jul 24, 2003 | 09:00 PM
CFI-EFI's Avatar
CFI-EFI
I run 275/35/18
Thanks,
Doug
My 1984-1989 parts book only covers the stock, 16" and 17" tires for those years. I can figure it manually if you can give me an accurate rolling diameter for that tire. I can tell you how to measure it if need be. Good luck, and...
RACE ON!!!
Old Jul 24, 2003 | 09:40 PM
Dougs 90's Avatar
Dougs 90
Tell me how, I believe it is the same diameter as the 17" wheel, or real close. you tell me how to do it and I would appreciate the info!
Thanks,
Doug
Old Jul 27, 2003 | 02:31 PM
CFI-EFI's Avatar
CFI-EFI
My chart show the gears for P255/50/16 tires and also P275/40/17 and P315/35/17's. Since we started this, I have seen a speedo gear chart posted at: http://www.corvetteforum.net/c4/vett...Gearshtm.shtml
However, I don't see any 18" tires listed. If you KNOW that your tires are the same circumference, or rev/mile as one of thoses listed, go with the chart. Otherwise, mark the tire at the ground. Mark the ground at that same spot. Move the car any convenient number of tire revolutions, and mark the ground where the tire mark meets the ground, again. Measure the distance between the marks on the ground and divide by the number of revolutions made. This is the loaded, rolling circumference of YOUR tire. I can take it from there. Technically, one revolution is sufficient, but more revs, minimizes or averages any "error". Good luck, and...
RACE ON!!!
[Modified by CFI-EFI, 12:34 PM 7/27/2003]
To Speedo Correction Gears???
