Hypertech Chip or coolant temp switch is loosing its mind
The other day my main fan had a brain fart and decided to take some time off. Well today it's working but it comes on at 174 rather than 160 degrees normally. Whats up with that?
Anyone have similar problems in the past?
Re: Hypertech Chip or coolant temp switch is loosing its mind (AGENT 86)
I am going to gander that your main fan is still being controlled by the ECM.
The backup switch in the cylinder head won't complete the circuit until you are into the 2's.
The coolant sensor that feeds the ECM is a different sensor/sender than the one that feeds the Digidash, so really either could be off. Also, the back-up switch completes the trio of coolant-related sensors on your car.
But my only question is this: If your fan normally comes on at 160*F, when the heck does it turn off? Unless you are always above ~35 MPH, that thing is going to be on all the time...
Thanks Again
Dan :smash: :smash:
:cheers:
Well I am pretty sure the Hypertech turns on the fan at 174 (or somewhere around there). I have one as well, and I know it doesn't turn on until about 10F higher then the 160Tstat that is installed. Why it stopped for a while seems a mystery, but seems like it is functioning normally.
Re: Hypertech Chip or coolant temp switch is loosing its mind (rsafier)
I may have to go review my theory of operation for an 85 Vette, but I seem to recall that the fan is controlled by a sensor on the head and the engine temp indicator is on the front of the manifold. The Hypertech chip with the lower temp does not control the fan, but the chip allows the ECM to go into closed loop at a lower temp. If you used the lower temp thermostat without the chip the ECM would wait for the engine to get up to operating temp and it would never get there. Don't recall if that condition times out or not. Anyway I think your problem is the fan sensor not the ECM/chip.
Or you could do what some of us have done. My fan is wired to be on all the time. Also run the Hypertech chip.
