exhaust -cat back for 84
Old Jul 25, 2003 | 12:11 AM
vettenik84's Avatar
vettenik84
Default exhaust -cat back for 84
just had stainless exhaust w/cat and dynomax mufflers installed--- sounds mean---- however, the rumble at 2000rmp is making me go deaf-- i guess i will be crawling under the car and see if all hangers and connections were properly installed-- any suggestions/thoughts would be appreciated :smash:
Old Jul 25, 2003 | 01:11 AM
TIMSPEED's Avatar
TIMSPEED
Default Re: exhaust -cat back for 84 (vettenik84)
What exhaust did you have installed exactly? The Flowmaster/Borla/Magnaflow are all going to have that "resonance" Try adding a cross-over tube, I think it helps...
Old Jul 25, 2003 | 01:25 AM
vettenik84's Avatar
vettenik84
Default Re: exhaust -cat back for 84 (TIMSPEED)
i believe i was told they were dynomax--- i to confirm when i get under the car--- i think the name is stamped on the outside of the mufflers.--- thanks for your thoughts--- i guess i have to live with it --- i alreadly got $1100 invested in the installation and parts--- putting i a crossover pipe --i assume involves removing the new "y" installed behind the new cat and replacing it? :iagree: thanks for your input ---
Old Jul 25, 2003 | 01:31 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
I have an '84 vette....using the best "FLOWMASTER".......with the ZR1 tips.....
no problems......
The FlowMasters have proven how great they are....
Also using a Random tech cat......
Fantastic.....
You should follow my example...
go to.....www.crossfire.webhop.net
and register.....
get the best info......like ram air....etc....etc.....
Good Luck
tony
:cheers: :grouphug:
Old Jul 27, 2003 | 10:04 PM
vettenik84's Avatar
vettenik84
Default Re: exhaust -cat back for 84 (oldace84)
thanks for the reply-- i am new to this forum--- so i was not able to get advice before ordering new system--- i will check out web site noted--
thanks again
nick :seeya
[Modified by vettenik84, 10:05 PM 7/27/2003]
To exhaust -cat back for 84
