MSD 6AL need help
Old Jul 26, 2003 | 09:26 AM
fiberglasscoffin's Avatar
fiberglasscoffin
Default MSD 6AL need help
MSD 6AL have it hooked up in my 94 now my tach jumps around and doesnt work right and im getting a service asr light when i hooked up the scan tool it said its getting a electric pulse i guess from the msd box what can i do to fix these problems? :confused:
Old Jul 26, 2003 | 09:30 PM
Tom Piper's Avatar
Tom Piper
Default Re: MSD 6AL need help (fiberglasscoffin)
Most makers of capacitive discharge ignition systems tell you to bypass the tach filter.
As far as I know, the only C4 that didn't have a tach filter is the '96. On the '96, the ECM has a dedicated tach signal output from the ECM to the tach. On the others, the tach is normally driven from the ignition coil negative side. Since this signal has spikes on it, the tach filter is needed to eliminate the spikes. But, with the CDI systems, there are no spikes, so the tach filter isn't needed.
Tom Piper
Old Jul 26, 2003 | 09:31 PM
fiberglasscoffin
nobody has had this problem before hooking up a msd 6al box?
Old Jul 26, 2003 | 09:43 PM
Alcee1's Avatar
Alcee1
Mine works fine on my 84
Old Jul 26, 2003 | 09:46 PM
cprgmr's Avatar
cprgmr
You have to bypass the tach filter. On mine, the filter had two white wires and a black wire (looks like a small "rubbery" box). Simply cut the two white wires (make sure you leave enough room to reconnect if needed) and wire them together. I'll see if I have some pics of the filter itself... :)
Old Jul 26, 2003 | 10:02 PM
fiberglasscoffin
Default Re: MSD 6AL need help (cprgmr)
thanx for the info pictures would be a bonus ever here of the asr light coming on after hooking up the msd box?
Old Jul 27, 2003 | 01:09 AM
cprgmr's Avatar
cprgmr
Haven't heard of it, mine didn't come on after the install...
Old Jul 27, 2003 | 04:54 PM
Tom Piper's Avatar
Tom Piper
The same tach signal that goes to the tach from the tach filter goes to the ABS/ASR computer for ASR activity.
When you bypass the tach filter, I suspect that not only will it fix your tach, it will fix your ASR problem.
Tom Piper
[Modified by Tom Piper, 4:55 PM 7/27/2003]
To MSD 6AL need help
