Dex-Cool or not?
Old Jul 26, 2003 | 01:27 PM
Yellow C-4's Avatar
Yellow C-4
Default Dex-Cool or not?
I have a '92 LT-1. I'm getting ready to flush the cooling system, and was wondering if I should replace the glycol base (yellow) coolant with (orange) Dex-Cool. My owner's manuel says use glycol, but newer models (also with LT-1s) say to use Dex-Cool, apparently for aluminum heads.
What's the story about Dex-Cool? Should I switch?
Old Jul 26, 2003 | 01:48 PM
jefft84's Avatar
jefft84
Default Re: Dex-Cool or not? (Yellow C-4)
Leave well enough alone, use the regular stuff and stay away from sealnt additives. Do a search on dexcool here one the forum.
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
If you decide to make the change be absolutely positive that all the glycol stuff is flushed from the system first. Dexcool will turn to a muddy paste if mixed with glycol antifreeze.
My wife's Grand Prix came from the factory with Dexcool. Somewhere along the line someone topped off the antifreeze with the green stuff. The entire system was packed with a muddy brown paste and had to be cleaned then flushed. :yesnod:
Old Jul 26, 2003 | 01:51 PM
subman's Avatar
subman
From all the posts I have read and info I have gathered, if your motor started with the green stuff, stay with it. Do NOT mix the two. You cannot purge the block, radiator and heatercore well enough to change without problems.
There are numerous posts regarding Dexcool/Greenstuff. I would go back and research the posts.
Subman
Remember the Wave
Old Jul 26, 2003 | 03:10 PM
Strick's Avatar
Strick
Default Re: Dex-Cool or not? (subman)
:iagree: Please don't change to Dexcool. Your LT-1 is not designed for its use. Trust us on this one, IF IT CAME WITH DEXCOOL, THEN USE IT, BUT IF IT DIDN'T - DON'T USE IT :yesnod:
[Modified by Strick, 3:11 PM 7/26/2003]
Old Jul 26, 2003 | 05:30 PM
Yellow C-4's Avatar
Yellow C-4
Default Re: Dex-Cool or not? (Strick)
Thanks for all the responses...I'll stick with the glycol.
Old Jul 27, 2003 | 03:46 AM
skeet's Avatar
skeet
I changed from the green to Dex in my 85 and in my current 88. Never had any problem at all. I wanted to use Dex mainly because the lack of silicates means less wear on the water pump and its seals. Even though it has worked great after many years you guys here have bugged me up and I do not think I will use it in my 95 which came with the green. I will be draining the whole system in the 95 by removing and replacing the lower radiator hose. If it looks like all the cool got out I might be tempted to use the Dex.
Old Jul 27, 2003 | 07:31 AM
SouthernSon's Avatar
SouthernSon
'81 mercedes with Dex for 2 years. No problems. I had drained the block, heater and radiator for engine work. I suppose the combination with residual green may cause problems if one were to mix, but I love the Dex!
Old Jul 27, 2003 | 09:12 AM
sraft's Avatar
sraft
Default Re: Dex-Cool or not? (skeet)
If you pull the knock sensors, you can flush the block very thoroughly.
Old Jul 27, 2003 | 02:28 PM
Ericthewolf's Avatar
Ericthewolf
Default Re: Dex-Cool or not? (sraft)
NOT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!
Old Jul 28, 2003 | 12:37 AM
GDP's Avatar
GDP
I use nothing but Dexcool. Better for aluminum heads and stuff.
Old Jul 28, 2003 | 01:31 AM
BAM92's Avatar
BAM92
Default Re: Dex-Cool or not? (GDP)
If your car came with it use it if it didn't don't change.
Old Jul 28, 2003 | 06:09 PM
sundbergjc's Avatar
sundbergjc
Default Re: Dex-Cool or not? (BAM92)
DexCool and the regular stuff are not compatible. If it came with one or the other originally DO NOT SWITCH. You can never, ever totally flush the system of either.
:nonod:
Old Jul 28, 2003 | 11:33 PM
TA's Avatar
TA
I know that most say don't do it, but I converted to dex-cool several years back in my L98 and have had no problems :yesnod:
Old Jul 29, 2003 | 06:58 AM
Dark-Knight's Avatar
Dark-Knight
Stay with the glycol.
[Modified by Beautiful Beast, 5:58 AM 7/29/2003]
Old Jul 29, 2003 | 05:56 PM
R23HTC's Avatar
R23HTC
Default Re: Dex-Cool or not? (Beautiful Beast)
I switched to Dexcool when the 383 was put in. No problems yet.
To Dex-Cool or not?
