Install looks easier than the L98 intake itself.Once you get the L98 TPI off the motor,the miniram is once piece and should be a much easier bolt in.
Maybe Ld85 here can shed more light,hes got this set up too.
It is very simple, takes no more than 30 minutes to put in place.
There is really now re routing, just buy their fuel rails for your model year and you may need to change your throttle cable linkage to the 1985 model year linkage but call them and ask them for sure. Also buy there thermostat housing and you are set.
