Need help with trans (700-r4). Having problems getting it into drive.
I just picked up an 1989 vette from my brother. The C4s are a blast! However, The car is having a problem shifting in to Drive. What happens is when you slide the shifter it seems like it wont lock into the gear. If you sort of slam it back from neutral to drive then it engages. All the other gears click right in, no problems. I don't know a whole lot about automatics, is there an adjustment that can be made, or is something worn in the shifter? I don't believe its the trans as there is not slipping and once it's in it doesn't pop out. Any tips?
Thanks in advance,
Christ
I just took it to a local trans. shop that was offering a special on trans fluid replacement and adjustment (it was like $29.99). I had them replace the fluid, the filter and gasket and adjust the cable. After that it's been pretty good to me.
