single mass conversion-DONE!!!!
Old Jul 29, 2003 | 02:46 PM
corvette90's Avatar
corvette90
Default single mass conversion-DONE!!!!
hi all
ive done the SM Con my 90 L98
used a FW from DRM..
ok...what happened
car revs definitively faster, no slipping, the only downside is the well known Tranny rattel, but i can live with it..
if i can help anybody, ask....
and a BIG THANK YOU to all Forum members...you helped me a lot !!!!
Old Jul 29, 2003 | 02:56 PM
bogus's Avatar
bogus
Default Re: single mass conversion-DONE!!!! (corvette90)
:cool:
Any vibrations? I have heard of vibrations caused by the flywheel not being balanced with the engine internals.
Old Jul 29, 2003 | 03:16 PM
corvette90's Avatar
corvette90
Default Re: single mass conversion-DONE!!!! (bogus)
no vabriatons, runs even smoother than before...
Old Jul 29, 2003 | 03:25 PM
bill mcdonald's Avatar
bill mcdonald
what clutch are you using?
Old Jul 29, 2003 | 03:34 PM
corvette90's Avatar
corvette90
Default Re: single mass conversion-DONE!!!! (bill mcdonald)
i used a Camaro Disc, #12551309 from year 93-97 , 1 1/8 *26 Spline, sprunged
it looks very strong, 5 double springs in the disc
Camaro FW , machined fron DRM, Stock Pressure plate, Corvette throwout bearing
Old Jul 29, 2003 | 05:51 PM
JF_AH_64's Avatar
JF_AH_64
So the rattle isn't unbearable? I am trying to decide on which route to go when I replace my clutch, I can deal with a some noise, I have heard different reports thanks.
Old Jul 29, 2003 | 05:55 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Default Re: single mass conversion-DONE!!!! (JF_AH_64)
The rattle in mine was mostly at idle. Didn't bother me much, but if it had been a dash rattle I would have gone :crazy:
Old Jul 30, 2003 | 12:19 AM
corvette90's Avatar
corvette90
Default Re: single mass conversion-DONE!!!! (93Polo)
what he said...its a clacking noise in variuos frequency...
it´s most noticeable at idle, when you push the clutch, its gone...
i think, the noise is not tooo bad, as long as you know why and where it appears... ;)
Old Jul 30, 2003 | 10:04 AM
aggie88's Avatar
aggie88
Since you are "fresh meat" from a ZF tranny drop down, could you provide me some pointers in removing the ZF tranny for a clutch replacement? I am contemplating doing the job myself on my 95 LT1 but am reminded of how difficult it was to maneuver the trans-to-diff brace in and out of my od 86 4+3 car.
Old Jul 30, 2003 | 02:50 PM
vvv90's Avatar
vvv90
Default Re: single mass conversion-DONE!!!! (aggie88)
:lurk:
Old Jul 30, 2003 | 03:42 PM
bill mcdonald
Default Re: single mass conversion-DONE!!!! (vvv90)
Does that rattle go away when you accelerate? or does it come back when you coast in gear?
I was wondering if it causes any false knock.
I have the DRM flywheel, I installed it about 5 years ago, but my clutch disk is he centerforce dual friction and it does not have the springs in it, which made so much racket that I pulled the flywheel right back out. I started the car, let the clutch out in neutral, and it said this cannot be in here like that. Shut it down, and ripped it right back out.
Old Jul 30, 2003 | 03:49 PM
corvette90's Avatar
corvette90
hi..a special answer for aggie
ok, i can tel you from experience...
first of all, fix the the engine, means, put some blocks of wood under the oil pan, so that i cannot press the distributor against the firewall-or it will break
drain trans oil, so it cannot leak out later
next, support the trans with a floor jack( extremley helpful!!) under the drain plug and loose the screws, diff and tranny..be careful, the nuts on top of the beam are locking nuts so you need to hold them
than remove the drive shaft, just unscrew the straps at the diff, push it in the trans , move it out oft the beam, and pull out of the trans...should move very easy
remove the center console, and remove the 4 egg nuts from the rubber boot
next, i drive the beam towards front end, using a block of wood and a hammer...just look for an edge to push on it
than remove the wood blocks under the engine and let the flóor jack down just that the distributor don´t hit the firewall..push beam forward, and wiggle it out
all i can say, that installation was much easier than removal..
than pump up the jack so that engine-trans is level
remove the trans-bellhousing bolts, and drive it out aos much as you can..
than let jack down, so that the shift lever clears with the rubber boot..
at this point the splines of the input shaft should be already out of the disc, andyou can remove the trans..always observe the shift lever...it cllears, but very little...
istallation was also much easier than removing
i think, thats ist, if you have further questions, just drop an email..
Old Jul 30, 2003 | 03:59 PM
aggie88's Avatar
aggie88
Thanks my Austrian friend for passing on that info. It sounds a lot like the 86 4+3 job I did a few years ago. The toughest part does sound like reaching those lock nuts and maneuvering the C-brace so the transmission can clear the splines - just like the 4+3. And that tranny was a monster too with the overdrive unit stuck on the end. Thanks for the detailed tips!!!!
Old Jul 30, 2003 | 09:29 PM
Stingray1970's Avatar
Stingray1970
:iagree: I completed mine a short while ago, better than before. The transmission does make a bit more noise, but the change was worth it. I used GM transmission oil 5-30 wt, I think maybe the Castrol might reduce the noise a bit because of the higher viscosity. I'll probably change mine just to check my theory.
Old Jul 31, 2003 | 07:33 AM
corvette90's Avatar
corvette90
the rattle goes away under acceleration, and come back under coasting when little or no load is on the gears
Old Jul 31, 2003 | 06:07 PM
Rich B.'s Avatar
Rich B.
There's an easy fix for the rattle...
...Turn the radio up...
To single mass conversion-DONE!!!!
