Would leaking Valve cover gaskets cause a vacuum leak situation?
Re: Would leaking Valve cover gaskets cause a vacuum leak situation? (montie98)
Depends on how much oil is leaking
[Modified by 1MoorTym, 7:53 PM 7/30/2003]
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
My 85s need to be replaced. Should this be a top priority?
Generally you will get oil leaks way before you get a vacuum leak, if you ever get a vacuum leak IMHO
Try tightening the cover bolts, gently! I have to do this every now and then since they do work loose.
:seeya
:steering:
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Re: Would leaking Valve cover gaskets cause a vacuum leak situation? (jackdaroofer)
Assuming your pcv supply line (passenger side) isn't clogged, no.
If anything, you have too much crankcase pressure, and that's contributing to your valve cover leaks. :lurk:
Cruise-In VIII Veteran
They did in my case. I had both a leaking timing cover seal and the dreaded intake gasket. Code 32. Rather large leaks in both cases. Fixed both and no SES light since! :thumbs:
