91 vette codes
Old Jul 30, 2003 | 08:41 PM
6spd's Avatar
6spd
Default 91 vette codes
hi, can anyone tell me how to check codes. thanks
Old Jul 30, 2003 | 08:53 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: 91 vette codes (6spd)
Which system are you diagnosing?
Old Jul 30, 2003 | 09:41 PM
subman's Avatar
subman
Default Re: 91 vette codes (Jeffvette)
He should be using OBD1. If so, jumper wire between A and B pins on the terminal under the dash (driverside;over your right knee). Watch the SES lite in the panel. Will flash 1 then 2 three times. Then count the flashes for the codes. The code flashes will flash 3 times each and then return to 1 / 2 when complete. The error codes are listed somewhere on CF and are also in most of the manuals.
Good Luck
Subman
Remember the Wave
found this a few posts down
http://www.c4vettes.com/ecm.htm
[Modified by subman, 7:44 PM 7/30/2003]
Old Jul 31, 2003 | 11:59 AM
Jeffvette's Avatar
Jeffvette
Default Re: 91 vette codes (subman)
Yes, A-B is for engine functions, but if he wants to read the ABS, it's a different pin, same with the Airbag system, the shocks etc.
Old Jul 31, 2003 | 01:57 PM
Steel Blue 91's Avatar
Steel Blue 91
Jumper the A and G. That turns the digital portion of the dash into a code reader.
Go here to learn more:
http://www.c4vettes.com/codes.htm
Old Jul 31, 2003 | 03:40 PM
6spd's Avatar
6spd
Default Re: 91 vette codes (Steel Blue 91)
okay thanks guys
To 91 vette codes
