You can gain power with more FP IF you have increased the airflow in your intake to make use of any extra fuel available. Extra pressure will atomize the fuel better but the ECM will just adjust the duty cycle of the injectors based on the rich/lean info from the O2 sensor. You won't gain anything if your engine can't use the extra fuel.
