Brake-in for new cam
Jul 31, 2003 | 03:31 PM
I've read in John Lingenfelter's book that on first start, engine should be
immediately reved to 1500-2000 rpm and kept like that for 15-20 minutes.
How did You brake-in your new cam?
Jul 31, 2003 | 03:39 PM
Re: Brake-in for new cam (Sliding)
At least 20 minutes above 2000 rpm! Sounds and feels great with open headers! What a rush!
The increased idle speed insures proper lubrication and tappet spin to allow a proper wear pattern to develope! Then for about 500 miles avoid driving at a constant speed for long periods of time. You don't have to blip the throttle but gentle increases and decreases...after that you're gold!
:cheers:
Jul 31, 2003 | 03:43 PM
Quote:
I've read in John Lingenfelter's book that on first start, engine should be immediately reved to 1500-2000 rpm and kept like that for 15-20 minutes.
This is correct for a non-roller cam. Roller camshafts need no break-in period, just let the engine warm up and run it.
Jul 31, 2003 | 03:53 PM
Cruise-In II Veteran
Though roller lifters don't rotate it is likely a good idea as the other valve train components still need to wear in on initial startup.
Jul 31, 2003 | 04:46 PM
You have a Roller lifters so you dont have to brake them in.
What you are reading is for engines that dont have a roller cam.
Jay
Jul 31, 2003 | 05:43 PM
Re: Brake-in for new cam (MrJay)
Don't forget to put lots of assembly lube on everything!
Jul 31, 2003 | 06:07 PM
Re: Brake-in for new cam (Gar)
unless its a roller cam., then dont put any assembly lube on the cam or lifters, oil only...
Jul 31, 2003 | 07:25 PM
Re: Brake-in for new cam (neverendingproject)
:iagree: :iagree:
