Backfire on deacceleration????
Old Aug 1, 2003 | 04:58 PM
shane99's Avatar
shane99
Default Backfire on deacceleration????
When i back off the accelerater at anything over 3,000rpm I will get a single or short series of backfires out the exhaust. Any ideas as to whats causing this? No codes and otherwise runs great. Its a 92 LT1.
Old Aug 1, 2003 | 06:29 PM
GRX's Avatar
GRX
Default Re: Backfire on deacceleration???? (shane99)
Sounds like a very rich mixture....but you say it runs good otherwise? :confused:
Old Aug 1, 2003 | 07:01 PM
C10 JDR's Avatar
C10 JDR
Air leak on exhaust. Head to manifold probably.
Old Aug 1, 2003 | 07:19 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Timeing...I think so. Yeah, maybe the fuel mixture. But with injectors????
Just my thoughts.
tony
:chevy :chevy
[Modified by oldace84, 4:20 PM 8/1/2003]
Old Aug 1, 2003 | 07:22 PM
dizwiz24's Avatar
dizwiz24
Mine does this all the time. I was told this gurgling, popping is normal. I think it sounds cool anyways.
Old Aug 1, 2003 | 07:34 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Backfire on deacceleration???? (britvette)
:iagree:
Old Aug 1, 2003 | 09:38 PM
rsafier's Avatar
rsafier
Mine does the same now that I switch over to a borla exhaust. I like the effect, at least from what I have heard it really doesn't hurt anything.
Old Aug 2, 2003 | 01:04 AM
shane99's Avatar
shane99
Default Re: Backfire on deacceleration???? (rsafier)
I have a bike with a header on it that does the same thing. Most guys user a PCIIIr w/ a custom map to change the timing and advance based on throttle position and rpm. So say that it may burn the valves but thats on a 200hp,
73 cid (1200cc) engine that revs to 11,500. So not the same in many respects. Its good to hear that theres no residing it will hurt this or that which was my main concern.
Oh yeah it does sound cool coming outta the Hooker Aerochambers.
[Modified by shane99, 6:08 AM 8/2/2003]
Old Aug 6, 2003 | 04:31 PM
hotdawg1's Avatar
hotdawg1
Mine started that too. It runs great otherwise. I like the sound, because it grumbles almost like it is growling and makes a few popping sounds. If you gear it down on decceleration you can really drag it out. :yesnod: :lol:
:flag
Old Aug 6, 2003 | 04:48 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Backfire on deacceleration???? (hotdawg1)
Mine does this very loudly now, it wasn't like this before. I can hear it over the motor at any speed, and I have glass-pak exhaust, so the car is pretty loud to begin with.
I'm sure that it's because of a blown header gasket, and a rich mixture. I have all the parts on my shelf, and in a week I'll have a garage to work in. :hurray:
Old Aug 6, 2003 | 05:02 PM
Darkness's Avatar
Darkness
Default Re: Backfire on deacceleration???? (GRX)
Its actually a lean condition that causes this, what causes this is normally a exhaust or and intake upgrade that will make the engine flow better and therefore make it go a little lean, when off throttle. Its not a problem to do this, in fact all high performance engines will do it, check race cars just before entering corners where they downshift and you see fire spit out the pipes.
Later :cheers:
Old Aug 7, 2003 | 11:43 AM
C4DC's Avatar
C4DC
St. Jude Donor '06
Mine has done the same since I added my Corsa exhaust...
Old Aug 7, 2003 | 02:43 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
If they are not loud, then it is nomal. My '93 does this too, and it is pure stock.
To Backfire on deacceleration????
