How Do You like YOUR MAF?
Old Aug 2, 2003 | 09:35 PM
Southern Comfort's Avatar
Southern Comfort
Default How Do You like YOUR MAF?
Since MAF seems to be a hot topic. Chime in on where you stand on the subject
I screwed this up...someone please add Totally Gutted
[Modified by Southern Comfort, 6:39 PM 8/2/2003]
Old Aug 2, 2003 | 10:31 PM
MrNuke's Avatar
MrNuke
Default Re: How Do You like YOUR MAF? (Southern Comfort)
I am currently running with a bone stock unmodified MAF, and did my dyno runs last week like that. I should be getting another MAF for my car that I can modify (gut and remove screens), and will do a dyno again.
See if it helps anything... Should be done in 2 weeks.
Old Aug 3, 2003 | 02:14 PM
Southern Comfort
Default Re: How Do You like YOUR MAF? (MrNuke)
That will be interesting to see. Keep us posted. :smash: Always workin' on it.
Old Aug 3, 2003 | 03:50 PM
1MoorTym's Avatar
1MoorTym
Finally some real evidence, looking forward to the results.
I just came back from a ride after modifying mine. The butt-o-meter seems to feel better throttle response and improved pull (at least up to what the road permits). The good news is that is seemed just fine without the screens and the heat sinks. I also put on a cut lid as well, so the combination at least seems like a good thing.
Casting a vote for totally gutted :D
Old Aug 3, 2003 | 07:10 PM
C10 JDR's Avatar
C10 JDR
Default Re: How Do You like YOUR MAF? (1MoorTym)
I am a bit confused by this. (probably the drink, but ..), it seems to me that the biggest restriction in the inlet airflow is not the screens, or the poor TPI runners, (I feel a bit sorry for them), but the throttle butterfly valve!.
How is a small increase in flowthrough trhe MAF going to make any difference when you have a great big throttle blade impeding the flow? - unless you're at full throttle.
Having said that - I have removed the screens on mine.
:cheers:
Old Aug 3, 2003 | 08:02 PM
GlennS87's Avatar
GlennS87
Default Re: How Do You like YOUR MAF? (britvette)
At the next ECSCC I am going to try out a Wells MAF to compare the two. I currently use a completed gutted Bosch MAF. I doubt there will be a difference but it should be interesting.
Old Aug 3, 2003 | 08:10 PM
MrNuke's Avatar
MrNuke
Default Re: How Do You like YOUR MAF? (GlennS87)
I tried out the WELLS / Microtech (same design) new MAF and on my '85 I had a hunting idle solid from 500-900rpms.. Tried two new units. Was nto my car and wasn't a defective part. The engineer at the company swore up and down it was 'trubulence' caused by my mods that caused it.
Funny... Sicne I got a stock style Bosch reman, everything's been good..
[Modified by MrNuke, 8:11 PM 8/3/2003]
Old Aug 3, 2003 | 08:15 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
Funny my 92 don't have one :D
Old Aug 3, 2003 | 09:31 PM
GlennS87's Avatar
GlennS87
I didn't get a hunting idle with the MAF but is a nasty propensity to set off a code 33. I noticed on the scantool that at idle I was getting about 20 gm/sec at idle versus 9-10 gm/sec with the gutted Bosch unit.
Old Aug 4, 2003 | 03:32 AM
hngacurv's Avatar
hngacurv
Mine is descreened, but I still have the fins.
To How Do You like YOUR MAF?
