Alternator bracket question
Old Aug 3, 2003 | 08:49 AM
SOVAIN1's Avatar
SOVAIN1
Default Alternator bracket question
I need a new alternator braket (the one on top) for my 85 and i was told that I have to buy one from a 85 and that no other years would fit. I thought all the L98's use the same bracket ,am I wrong?. Also do you know where I can buy one and for how much.
[Modified by SOVAIN1, 5:59 AM 8/3/2003]
Old Aug 3, 2003 | 08:58 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Alternator bracket question (SOVAIN1)
They are different on the 89 to the 85s......the 85s go way back and on the 89s they are to the first set of bolts. I'm assuming your talking about the smaller backet, and not the large one that hold most of the alternator.
Old Aug 3, 2003 | 09:37 AM
87vette's Avatar
87vette
I have an 87 and I have a smaller bracket to hold the alternator and smog pump in place. However mine broke due to age.. and I bought one from a fellow forum member from a 1986 Vette. When I recieved it, it was bigger than the bracket that I have. I found the reason was because early 86 Vettes had the iron cast heads.. while the later ones had the aluminum heads. I'm not sure if your 85 has the same or not.. but I got a bracket for sale in the FS section. :cheers:
Old Aug 3, 2003 | 10:22 AM
SOVAIN1's Avatar
SOVAIN1
Default Re: Alternator bracket question (87vette)
If it will fit my 85 i will buy it. DO you have a pic of it?
Old Aug 3, 2003 | 11:59 AM
87vette's Avatar
87vette
Email sent with pic.
Old Aug 3, 2003 | 12:05 PM
vettek50's Avatar
vettek50
what is the actual differance between 85 and 89 brackets for alternator? is the air pump main bolt located in the same place? :smash:
To Alternator bracket question
