Proper spark plug gap?
Old Aug 3, 2003 | 02:07 PM
dtorc4's Avatar
dtorc4
Default Proper spark plug gap?
I can't find any info on what I should set my gap to. I'm running 3 heat range plugs right now, but they are fouled from fuel. On the advice of several people, I'm going up two heat ranges to a 5. The current gap is .035. Should I stick w/ the same gap, or what?
Old Aug 3, 2003 | 07:26 PM
bogus's Avatar
bogus
Default Re: Proper spark plug gap? (dtorc4)
:eek:
damn. have you checked the web sites for the spark plug makers?
according to the NGK site, fouling is caused by:
Fouling
* Will occur when spark plug tip temperature is insufficient to burn off carbon, fuel, oil or other deposits
* Will cause spark to leach to metal shell...no spark across plug gap will cause a misfire
* Wet-fouled spark plugs must be changed...spark plugs will not fire
* Dry-fouled spark plugs can sometimes be cleaned by bringing engine up to operating temperature
* Before changing fouled spark plugs, be sure to eliminate root
cause of fouling
I know some of it's a "duh", but it makes me wonder if the heat range change will not fix it... I would also try going up to .040 for the gap...
Old Aug 3, 2003 | 07:52 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Proper spark plug gap? (bogus)
:eek:
Fouling
cause of fouling
:iagree: But here's an old hot rodders trick
Open the gap to .050, will give you a much larger exposed spark area and more power
but will also result in decreased plug life.
:seeya
:steering:
Old Aug 4, 2003 | 10:26 AM
dtorc4's Avatar
dtorc4
Default Re: Proper spark plug gap? (jackdaroofer)
:seeya
:steering:
Well, right now I can't afford shorter plug life. I'm going back to the sandbox tomorrow and my wife will be driving it. I don't want her to have to deal with problems on the Vette. Maybe I will bump it up to .040 though.
To Proper spark plug gap?
