removing smog pump
Old Aug 4, 2003 | 04:29 AM
garandfan's Avatar
garandfan
CI 5-6-7-8-9 Veteran
Cruise-In 7 Car Show Winner
Default removing smog pump
Hey guys, just a thought but has anyone done this, and did you get a shorter belt, or put in a free running pulley just to match the stock belt. Are these available somewhere?
Frank
Old Aug 4, 2003 | 07:31 AM
C10 JDR's Avatar
C10 JDR
Default Re: removing smog pump (garandfan)
You put in a free running pulley, I think Breathless Performance have them, but I made my own after looking at the pictures on their website.
Old Aug 4, 2003 | 12:50 PM
vettek50's Avatar
vettek50
i have built my own, no serpentine belt to replace use existing belt! i have several for sale to forum members,,check out links in signature: :thumbs:
Old Aug 4, 2003 | 12:51 PM
vettek50's Avatar
vettek50
i have built my own, no serpentine belt to replace use existing belt! i have several for sale to forum members,,check out links in signature: :thumbs: if interested IM for details
Frank
Old Aug 4, 2003 | 01:15 PM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
Default Re: removing smog pump (vettek50)
So Vettek50,
You would'nt have come accross a similar replacement for the A/C now would you?
I am currently considering a fab job on this myself, but why re-invent the wheel so-to-speak?
Matt
Old Aug 4, 2003 | 01:59 PM
vettek50's Avatar
vettek50
Default Re: removing smog pump (MJT383NO2)
no i thought i would keep the A/C...i think many would want to (keep)..however, on the 87 , thr are 2 main mounting points..the center of the A/C pully is about 9/16" c/l above and 3" from the right mounting point..a polished aluminium bracket with same size pulley could be fabbed to replace the A/C...may not be able to located same diameter pulley..so it would be a custom build..BUT COULD REPLACE BELT TO FIT......
as for reventing the wheel:::PRICELESS....:thumbs:
for larger view: http://www.photohost.org/gallery/dat...94IMG_0123.jpg
So Vettek50,
Matt
Old Aug 4, 2003 | 02:21 PM
Matt383's Avatar
Matt383
Vettek50,
Thanks for the reply.
RE: The link you provided...The picture is too dark for me to see the config of the belt, if that is what I am supposed to get from it.
Do you have a diagram??
Thanks again.
Matt
Old Aug 4, 2003 | 05:06 PM
vettek50's Avatar
vettek50
the pic is showing the mounting points..of what could be the a/C replacemnet bracket...if too dark use your software to brighten up..sorry no diagrams available..wouldn't be soon...however you suggested building ....send me the plans when you have them ...???...
effort in build : rating 1- 9 ...mine is 0-1...:priceless...however, should you need one i would be happy to build ONE for u...thks ;)
To removing smog pump
