Roof Panel
Old Aug 4, 2003 | 12:13 PM
hillb's Avatar
hillb
Cruising
Default Roof Panel
I just got an 85 Vette, but no owners manual. What is the procedure to remove the roof panel. Any sprcial ways or precautions?
Old Aug 4, 2003 | 12:41 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: Roof Panel (hillb)
Loosen the 4 torx bolts(2 front 2 rear)
Lift front and pull away from rear
:cheers:
Old Aug 4, 2003 | 12:45 PM
chb88's Avatar
chb88
Don't try to drive it without the roof panel installed. It will handle like a Flexible Flyer. :auto:
Old Aug 4, 2003 | 01:03 PM
montie98's Avatar
montie98
Default Re: Roof Panel (chb88)
By all means drive the car with the roof panel off, its awsome. The car will have more flex to the body but thats about it
Old Aug 4, 2003 | 01:09 PM
Thanatos69's Avatar
Thanatos69
Default Re: Roof Panel (montie98)
I'm not sure about that year model, but I'm sure it pretty close to my '94. There are 4 hex head bolts holding the roof panel on. 2 of them are recessed in small holes under the sun visors and 2 are behind the driver and passenger seats in the rear pillar. You just need to remove the rear 2 and loosen the front 2 (the front 2 will not come out, they are clipped in to not fall out) Once you do that, you can remove the panel. If this is different for your year model, I'm sure someone will chime in with a correction to my instructions. Driving without the top on is a great experience, luckly I have both the 'Vette and a Mustang convertible so I can go topless with either car. One recommendation though, its going to be a hot, hot day (I live in TX, so its alway hot), I'd leave the top on. trying to take the top off after its been baking in the sun for a few hours is not fun, unless you have oven mitts!
Old Aug 4, 2003 | 03:18 PM
85vetteguy's Avatar
85vetteguy
Try http://www.helminc.com for owners manual. Good Luck, Guy
Old Aug 4, 2003 | 08:20 PM
redvette1986's Avatar
redvette1986
I think the Last Detail in Atlanta has owners manuals...plus all kinds of other goodies.
http://www.tld-corvette.com/
Old Aug 4, 2003 | 09:01 PM
MtlSphere's Avatar
MtlSphere
On my 85 the rear mounts have three torx heads visible on each side...remove the one in the middle! The front two are above(under) the visor and the bolts don't drop out.
:seeya Welcome to the forum! :flag
To Roof Panel
