Windshield Cleaning, Inside
Old Aug 4, 2003 | 03:28 PM
CAJUN C4's Avatar
CAJUN C4
Default Windshield Cleaning, Inside
This might sound weird but I can't seem to get the Inside of my Windshield clean...After cleaning I see streaks smudges etc. What's the best
method / product to clean it with?
Old Aug 4, 2003 | 03:35 PM
STL94LT1's Avatar
STL94LT1
Default Re: Windshield Cleaning, Inside (CAJUN C4)
I don't use any cleaner on the inside of my winshield, just a clean cotton cloth. Every cleaner that I have tried leaves a cloudy windshield.
Old Aug 4, 2003 | 03:47 PM
Scoob's Avatar
Scoob
1. Windex - the blue kind with ammonia, not that green with vinegar crap.
2. Use newspaper to wipe with, not paper towel or cloth. Use the black/white section only, not the comics, and not glossy ads.
You will not be disappointed.
Old Aug 4, 2003 | 03:49 PM
don hall's Avatar
don hall
Tough to out perform STONER-INVISIBLE GLASS. Use paper towel to clean, and a new towel to wipe dry.
Old Aug 4, 2003 | 03:52 PM
CAJUN C4's Avatar
CAJUN C4
Default Re: Windshield Cleaning, Inside (Oldman)
Where can I get some?
Old Aug 4, 2003 | 03:57 PM
don hall's Avatar
don hall
Stoner is available at most auto stores...
If you are applying a "dressing" to the dash, the evaporation may leave a "smudge" that will require a little more effort.
Old Aug 4, 2003 | 04:15 PM
Paul G's Avatar
Paul G
:iagree:
Old Aug 4, 2003 | 06:10 PM
1989redvette's Avatar
1989redvette
i use black and white newsprint and any type of quality glass cleaner and i have no streaks ..the newspaper actually polishes the glass... :thumbs:
Old Aug 4, 2003 | 06:39 PM
Thanatos69's Avatar
Thanatos69
Default Re: Windshield Cleaning, Inside (1989redvette)
I've been wanting to try Mother's Plastic Cleaner. The reason being, most of the 'film' and 'streaking' you see on the inside of windshield and glass is from the plasticizers (the chemical compounds that make the dash flexible) being released as the vinyl slows deteriorates from UV radiation. From what I've heard, Mother's Plastic Cleaner is good about removing this type of film as its also the root cause of the plastic windows on most convertibles filming over with age. A good dash protectant (one with UV blocking agents) will help reduce the dash from aging as quick. However you still will get the 'film' on your windows as the protectant breaks down from the UV instead of your dash.
[Modified by Thanatos69, 5:40 PM 8/4/2003]
Eric 96's Avatar
Eric 96
Mike, try buffing out the smudges the next morning with a dry cotton towel. :cheers:
Old Aug 4, 2003 | 07:26 PM
mjfox's Avatar
mjfox
use meguirars instant detailer
inside and out
Old Aug 4, 2003 | 07:31 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
:iagree:
To Windshield Cleaning, Inside
