water pump
Old Aug 7, 2003 | 11:43 AM
JordiZR1's Avatar
JordiZR1
Default water pump
Well, I found the reason for the dissapearing coolant in my 88, the water pump is seeping through the 2 little holes over and under the pulley shaft, the manual says the pump shaft seal is broken and I need a new pump.
What are the best sources to look at?, I am writing this from Europe, so answers like "walk down the road to the next Autozone and pick one from the shelf" are nor valid! ;)
I mean mail order part stores.
Thanks!
Old Aug 7, 2003 | 11:58 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: water pump (JordiZR1)
http://www.corvettecentral.com has a good listing for water pumps and related parts... #1-800-345-4122.. just looked in catalog 84-91 #244421 (new) alum (exc ZR-1) $79.99, #244376 High performance $124.95, Gasket (2) 1.97 ea. Hope this helps
Old Aug 8, 2003 | 04:54 AM
007rollie's Avatar
007rollie
Upgrade to a stewart components high flow water pump. I did this on my 89 and i have no regrets. 40% better flow capacity. http://www.waterpumps.com or call 906-789-2816 Your car would need the same pump that i purchased. part #13403 for 84-92 vette. All the info. you need is on there web site. I guess i should add purchase price $101.95 + shipping
[Modified by 007rollie, 9:57 AM 8/8/2003]
Old Aug 8, 2003 | 07:41 AM
Vic'89's Avatar
Vic'89
Default Re: water pump (007rollie)
I am running an Edelbrok unit, picked it up from Summit Racing.
Vic
To water pump
