91 L98 RR's
Old Aug 7, 2003 | 08:17 PM
Rays91L98's Avatar
Rays91L98
Default 91 L98 RR's
Planning on getting some RR's. Does anyone with a 91 w/ alum 113 heads have an opinion on brand and is it necessary to replace springs also?
:seeya
Old Aug 7, 2003 | 09:04 PM
AS84's Avatar
AS84
Default Re: 91 L98 RR's (Rays91L98)
I have a 90 (same heads, same motor) with crower 1.6's. They are a real nice piece but they have a little bit more meat on them which makes clearances too tight at the inside edge of the valve cover, they have to be modified. I would reccomend the comp cams pro magnum series. Your stock springs will be fine.
Old Aug 7, 2003 | 09:23 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Go with the ProMagnum 1.6:1 self-aligning RRs (don't know the Comp Cams P/N here), keep the stock push rods, install Comp Cams #981 springs, #728 Ti retainers, #728 10deg locks and use the #4753 shim pack to set install height.
If there is any interference, you will need to remove the studs and toss the stock push rod guides. These were used during factory assembly to roughly hold the push rods in position and so do not interfere with the stock self aligning rockers but may with 1.6:1s.
Toss the oil shedders from atop the stock springs to lighten up the valve train, install a set of GM seals (lower & O-ring uppers) and use FelPro valve PermaDry cover gaskets.
You will need to reduce the drip tabs inside the vavle covers and narrow the bolt bosses for clearance.
Use a little assemly lube on the tips of the push rods, under the RR push rod cuts and on top of the valve stems. Use engine oil to lube the RR bearings.
Old Aug 8, 2003 | 06:18 AM
Rays91L98's Avatar
Rays91L98
Default Re: 91 L98 RR's (65Z01)
Is it really necessary to get springs and retainers, I thought the Promagnums were a direct bolt-on for the 91 after removing drip tabs. I was leaning towards the pro mag's anyway from what I've read here and I just wanted to verify what's required and any snags encountered.
thanks
:seeya
Old Aug 8, 2003 | 06:56 AM
cshuman's Avatar
cshuman
65ZO1 are the valve stem seals you refer to the stock units or something different? If different do you know the part #s?
To 91 L98 RR's
