TB bypass?
Old Aug 8, 2003 | 07:25 AM
Corvettehumlan's Avatar
Corvettehumlan
Default TB bypass?
Whats that and how do U do it? :rolleyes:
Old Aug 8, 2003 | 08:20 AM
Lone Ranger's Avatar
Lone Ranger
Default Re: TB bypass? (Corvettehumlan)
Living in a cold climate area such as Sweden, you might be better off leaving it alone. The coolant is routed through the throttle body to help prevent frosting of the throttle body during cold weather operation.
Old Aug 8, 2003 | 09:27 AM
Strick's Avatar
Strick
Default Re: TB bypass? (Lone Ranger)
:iagree: :yesnod:
Old Aug 8, 2003 | 10:05 AM
vvv90's Avatar
vvv90
Default Re: TB bypass? (Strick)
Or you can just take 5 minutes and put it back when the weather gets cold. The mod does not require you to butcher the hoses. Just plug 'em.
TB Bypass and Fan mod are a must for hot weather driving. Don't let anyone tell you differently.
Here's the C4 tech tip on how to do it.
https://www.corvetteforum.com/techti...D=61&TopicID=2
[Modified by vvv90, 9:06 AM 8/8/2003]
Old Aug 8, 2003 | 12:45 PM
Lone Ranger
Default Re: TB bypass? (vvv90)
DO NOT PLUG the hoses! The TB gets its coolant feed from the steam tube-- the aluminum tubing that runs along the passenger inboard part of the valve cover. The steam tube receives steamed coolant from hot spots in the heads (if you look at back of motor there is a junction where the steam tube from driver side head passes its coolant to the steam tube from passenger side...passenger steam tube then routes this coolant to the tb) and condenses it back to liquid coolant. The flow of the liquid coolant back into the system must be preserved! You want to *bypass* it, not *plug* it. When you bypass you are still letting the coolant from the steam tube circulate back to the system, it just does not go through the throttle body any longer. If you plug the steam tube you risk warping or cracking the aluminum heads.
[Modified by Lone Ranger, 11:55 AM 8/8/2003]
Old Aug 8, 2003 | 01:17 PM
vvv90's Avatar
vvv90
:iagree:
You're right. I didn't plug mine, I have a brass coupler in mine. Do the same and you can't go wrong. If it's a problem, I'm surprised the part about plugging them is listed in the tech tips section. They should edit that part out.
Old Aug 8, 2003 | 03:42 PM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
:iagree: They must be coupled together. I made a tube from aluminum.
-Rick
Old Aug 11, 2003 | 12:15 AM
Corvettehumlan
Thanx for all the answers guys! :cheers:
Old Aug 11, 2003 | 12:28 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Save your time !!
It stays cool for a while then all the engine heat transfers through.
I'll be returning mine to original soon.
:cheers:
Old Aug 11, 2003 | 12:10 PM
vettek50's Avatar
vettek50
Default Re: TB bypass? (AGENT 86)
:iagree: DO NOT PLUG ,, BYPASS IS THE PROPER WAY.
Old Aug 11, 2003 | 01:18 PM
fiberglasscoffin's Avatar
fiberglasscoffin
Old Aug 11, 2003 | 09:22 PM
0to60n4.5's Avatar
0to60n4.5
Default Re: TB bypass? (fiberglasscoffin)
Nice ALL WHEEL DRIVE C4 you have there. Your making all the heat your TB needs in that pic. :D
Old Aug 12, 2003 | 12:41 AM
fiberglasscoffin
Default Re: TB bypass? (0to60n4.5)
i dont get it? :confused:
Old Aug 12, 2003 | 06:41 AM
FX GS's Avatar
FX GS
I thought he blew a radiator hose!! :eek: :rolleyes: :lolg:
Old Aug 12, 2003 | 08:51 AM
silver & red CE's Avatar
silver & red CE
Living in a cold climate area such as Sweden, you might be better off leaving it alone....
Actually, the frosting issue isn't anything to worry about. I've been driving my Vette and Impala SS with the bypass for over 6 years now, no problems with frosting. While Chicago isn't as cold as Sweden, we get our fair share of sub zero (F*) weather here. The issue isn't how cold it gets, but rather when there's lots of moisture in the air and it's just above freezing. In theory that's when the pressure drop across the TB blades could cause icing. But as we all know, air isn't a great gas for making a refridgerator. Really this is a legacy from carb'ed cars, the gas evaporating is a great refrigerant, just look at a 60's Corvair.
Eric
To TB bypass?
