injector problem??
Old Aug 8, 2003 | 07:07 PM
BTinIOwa's Avatar
BTinIOwa
Default injector problem??
having problem with my idle it keeps fluctuating up and down is this a problem with my injectors or is it the crossfire curse??? :reddevil
this is on the famous 84 vette :confused:
after the car has run for a short time after it has shut off it seems to get a bad case of vapor lock it dosen't want to start again when the ac is runing it seems to want to die also . :banghead:
[Modified by BTinIOwa, 3:21 PM 8/9/2003]
Old Aug 9, 2003 | 12:18 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: injector problem?? (BTinIOwa)
It might be a dirty IAC valve.
Old Aug 9, 2003 | 01:11 AM
FD2BLK's Avatar
FD2BLK
I don't think it is either of your injectors they typically wont cause an erratic idle. Need more information to help more.
What if any codes are there?
[Modified by ejfagala, 12:13 AM 8/9/2003]
To injector problem??
