It seems the return spring for the throttle has lost some umph, is this spring adjustable? It appears that often it won't close all the way back to the idle screw. I recently cleaned the entire TB, but this car had sat for years with the idle screw turned out, it seems to have weakened the spring.
ROCKY85 :flag
Question how taunt should the TV cable be when in the idle position? I've tried resetting it once.
Replace the spring.
It may be a binding tv cable though.
Disconnect the tv cable and operate throttle by hand to see if it is spring.
Good Luck !!
:cheers:
